LFXTAL082125RL3K
LFXTAL082125RL3K
    IQD
    SMD2016_4P
    无源晶振 25MHz ±10ppm 8pF 100Ω -40℃~+85℃
LFXTAL082125RL3K 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL082125RL3K Customer Part: Description 2 x 1.6mm SMD crystal Ceramic package with a seam sealed metal lid, hermetically sealed Model IQXC-42 Model Issue number 1 Frequency Parameters Frequency 25.0MHz Frequency Tolerance Frequency Stability ±10.00ppm ±15.00ppm Operating Temperature Range -40.00 to 85.00°C Overtone Order Ageing Fundamental ±3ppm max per year @ 25°C Electrical Parameters Outline (mm) 8.00pF 3pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 100µW max 100.00Ω max Environmental Parameters Shock: IEC 60068-2-27: 1000G, 1ms, 3 times in each of 3 mutually perpendicular planes Vibration: IEC 60068-2-6: 1.5mm amplitude, 10Hz-55Hz, 1min in 3 mutually perpendicular planes, duration 2hrs each plane (total 6hrs) Storage Temperature Range: –55 to 125°C Manufacturing Details RoHS Terminations RoHS Reflow Temp NiAu 260degC 10s Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: RL3K Pack Size: 3,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 6 Sep 21 0:41 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL082125RL3K
1. 物料型号:LFXTAL082125RL3K,客户部件编号未提供。 2. 器件简介:这是一个2 x 1.6mm的SMD晶体振荡器,采用陶瓷封装,带有密封金属盖,是密封的。 3. 引脚分配:有四个引脚,1和3为晶体,2和4为地。 4. 参数特性: - 频率:25.0MHz,频率容差为±10.00ppm,工作温度范围-40.00到85.00°C时为±15.00ppm,基础频率稳定性,25°C时频率老化每年最大±3ppm。 - 负载电容(CL):8.00pF,并联电容(C0):3pF,最大驱动电平:100µW,最大等效串联电阻(ESR):100.00Ω。 5. 功能详解:文档中未提供详细的功能解释,但晶体振荡器通常用于为电子设备提供稳定的时钟信号。 6. 应用信息:文档中未明确提供应用信息,但晶体振荡器广泛应用于需要精确时钟信号的电子系统中。 7. 封装信息:封装尺寸为2.0 x 0.8 x 0.5mm,焊盘布局最大尺寸为0.675mm,最小尺寸为0.5mm。 8. 环境参数:符合IEC 60068-2-27标准的1000G冲击测试和IEC 60068-2-6标准的振动测试。 9. 存储温度范围:-55°C至125°C。 10. 制造细节:符合RoHS指令2015/863/EU和REACh法规,MSL等级未适用。 11. 包装细节:符合EIA-481-D标准的胶带和卷轴包装,包装样式为RL3K,包装大小为3000个。
LFXTAL082125RL3K 价格&库存
很抱歉,暂时无法提供与“LFXTAL082125RL3K”相匹配的价格&库存,您可以联系我们找货
LFXTAL082125RL3K
    • 1+7.12800
    • 200+2.85120
    • 500+2.75400
    • 1000+2.71080
