LFXTAL071261REEL
LFXTAL071261REEL
    IQD
    SMD2016_4P
    无源晶振 27MHz ±10ppm 10pF 100Ω -40℃~+125℃
LFXTAL071261REEL 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL071261Reel Customer Part: Description Ceramic package with a hermetically seam sealed metal lid suitable for automotive applications. Qualified to AEC-Q200 and with IATF-16949:2016 release. Not suitable for safety critical applications. Model IQXC-42 AUTO Model Issue number 1 Frequency Parameters Frequency 27.0MHz Frequency Tolerance Tolerance Condition Frequency Stability ±10.00ppm @ 25°C ±100.00ppm Operating Temperature Range -40.00 to 125.00°C Overtone Order Ageing Fundamental ±5ppm max per year @ 25°C Outline (mm) Electrical Parameters Shunt Capacitance (C0) 10.00pF 3pF max Drive Level ESR 100µW max ***See Technical Notes*** Load Capacitance (CL) Environmental Parameters Storage Temperature Range: -55 to 150°C Qualified to AEC-Q200 Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 3,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Technical Notes ESR; 80ohms max Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 7 Feb 21 7:49 using Part Data Sheet V1.0017 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL071261REEL
物料型号:LFXTAL071261Reel
器件简介:该器件是一个陶瓷封装,带有密封金属盖,适用于汽车应用。它符合AEC-Q200标准,并已根据IATF-16949:2016发布。但不适合安全关键应用。
引脚分配:1. Crystal 2. GND 3. Crystal 4. GND
参数特性: - 频率:27.0MHz ±10.00ppm @ 25°C ±100.00ppm - 频率容差:未提供具体数值 - 频率稳定性:未提供具体数值 - 工作温度范围:-40.00 to 125.00°C - 老化:±5ppm max per year @ 25°C - 负载电容(CL):10.00pF ±3pF max - 驱动水平:未提供具体数值 - ESR:80ohms max - 封装轮廓尺寸:未提供具体数值
功能详解:文档未提供详细的功能解释。
应用信息:适用于汽车应用,但不适合安全关键应用。
封装信息:封装细节包括卷轴包装,符合EIA-481-D标准,包装大小为3,000,提供替代包装选项。
环境参数:存储温度范围为-55至150°C,符合AEC-Q200标准。
合规性:符合RoHS(2015/863/EU)和REACH标准。
销售办公室联系方式:提供了英国、德国、法国、美国的销售联系电话和电子邮件地址。
LFXTAL071261REEL 价格&库存
很抱歉,暂时无法提供与“LFXTAL071261REEL”相匹配的价格&库存,您可以联系我们找货
LFXTAL071261REEL
    • 1+13.60800
    • 200+5.43240
    • 500+5.24880
    • 1000+5.16240
