BS-187.500MBB-T
BS-187.500MBB-T
    TXC(台晶)
    SMD-6
    有源晶振 3.3V 187.5MHz SMD-6
BS-187.500MBB-T 数据手册
Think of Frequency Think of SMD LVPECL SAW Oscillators - Differential Output 7.0 x 5.0 x 1.6 mm BS Series come visit our site http://www.txccorp.com Oscillators Series Features .SAW base solution. H Y1 0 S S B 00 T B 212.5 .3.3V and 2.5V operation available. .LVPECL output, output frequencies 150 MHz to 700 MHz. .Excellent low phase noise and jitter. .Tri-State function available. .Applications : Fibre Channel, Gigabit Ethernet, Serial ATA, Serial Attached SCSI, PCI-Express, SDH / SONET. .RoHS Compliant / Pb Free. Electrical Specifications Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Item / Type BS Output Type LVPECL Output Load 50 Ω Oscillation Mode Fundamental Supply Voltage (VDD) 2.5 V , 3.3 V Frequency Range 150 ~ 700 MHz Overall Frequency Stability * ± 100 ppm , or specify Operating Temperature Range -10 ~ + 70 ℃ , - 5 ~ + 85 ℃ , or specify Storage Temperature Range - 55 ~ + 125 ℃ Voltage Vol ( Max. ) / Voh ( Min. ) VDD - 1.62 V / VDD - 1.025 V Rise ( Tr ) / Fall ( Tf ) Time ( 20 % ~ 80 % ) 1 nS Max. Supply Current 80 mA Max. Symmetry 45 ~ 55 % Start-up Time 10 mS Max. Phase Jitter ( 12 KHz ~ 20 MHz ) 1 pS Max. * Inclusive of frequency tolerance at 25 ℃, variation over temperature, supply voltage variation, aging and vibration. Dimensions Units: mm 72
BS-187.500MBB-T 价格&库存
很抱歉,暂时无法提供与“BS-187.500MBB-T”相匹配的价格&库存,您可以联系我们找货
