SIT2025BI-S1-XXE-125.000000 数据手册
SiT2025B
High Frequency, Automotive AEC-Q100 SOT23 Oscillator
Features
Applications
AEC-Q100 with extended temperature range (-55°C to 125°C)
Frequencies between 115.2 MHz and 137 MHz accurate to
6 decimal points
100% pin-to-pin drop-in replacement to quartz-based XO
Excellent total frequency stability as low as ±20 ppm
Industry best G-sensitivity of 0.1 PPB/G
LVCMOS/LVTTL compatible output
5-pin SOT23-5 package: 2.9 x 2.8 mm x mm
RoHS and REACH compliant, Pb-free, Halogen-free and
Antimony-free
Automotive, extreme temperature and other high-rel
electronics
Infotainment systems, collision detection devices, and
in-vehicle networking
Powertrain control
Electrical Characteristics
Table 1. Electrical Characteristics
All Min and Max limits are specified over temperature and rated operating voltage with 15 pF output load unless otherwise
stated. Typical values are at 25°C and nominal supply voltage.
Parameters
Symbol
Min.
Typ.
Max.
Unit
Condition
Frequency Range
Output Frequency Range
Frequency Stability
f
F_stab
115.20
-20
-25
-30
-50
137
MHz
Refer to Tables 14 to 16 for the exact list of supported frequencies
Frequency Stability and Aging
Inclusive of Initial tolerance at 25°C, 1st year aging at 25°C, and
+20
ppm
variations over operating temperature, rated power supply voltage
+25
ppm
and load (15 pF ± 10%).
+30
ppm
+50
ppm
Operating Temperature Range
Range (ambient)
T_use
-40
+85
°C
AEC-Q100 Grade 3
-40
+105
°C
AEC-Q100 Grade 2
-40
+125
°C
AEC-Q100 Grade 1
-55
+125
°C
Extended cold, AEC-Q100 Grade1
Supply Voltage and Current Consumption
Supply Voltage
Current Consumption
Vdd
1.62
1.8
1.98
V
2.25
3.63
V
6
8
mA
No load condition, f = 125 MHz, Vdd = 2.25V to 3.63V
4.9
6
mA
No load condition, f = 125 MHz, Vdd = 1.62V to 1.98V
DC
45
55
Tr, Tf
1.5
3
ns
Vdd = 2.25V - 3.63V, 20% - 80%
1.5
2.5
ns
Vdd = 1.8V, 20% - 80%
Idd
All voltages between 2.25V and 3.63V including 2.5V, 2.8V, 3.0V and 3.3V
are supported. Contact SiTime for 1.5V support
LVCMOS Output Characteristics
Duty Cycle
Rise/Fall Time
Output High Voltage
VOH
90%
Vdd
IOH = -4 mA (Vdd = 3.0V or 3.3V)
IOH = -3 mA (Vdd = 2.8V and Vdd = 2.5V)
IOH = -2 mA (Vdd = 1.8V)
Output Low Voltage
VOL
10%
Vdd
IOL = 4 mA (Vdd = 3.0V or 3.3V)
IOL = 3 mA (Vdd = 2.8V and Vdd = 2.5V)
IOL = 2 mA (Vdd = 1.8V)
Input High Voltage
VIH
70%
Vdd
Pin 1, OE
Input Low Voltage
VIL
30%
Vdd
Pin 1, OE
Input Pull-up Impedance
Z_in
100
kΩ
Pin 1, OE logic high or logic low
Input Characteristics
Startup and Resume Timing
Startup Time
T_start
Enable/Disable Time
T_oe
5.5
130
ms
ns
f = 115.20 MHz. For other frequencies, T_oe = 100 ns + 3 * cycles
Standby Current
I_std
2.6
µA
Vdd = 2.8V to 3.3V, ST = Low, Output is weakly pulled down
1.4
µA
Vdd = 2.5V, ST = Low, Output is weakly pulled down
0.6
µA
Vdd = 1.8V, ST = Low, Output is weakly pulled down
Rev. 1.7
May 22, 2019
Measured from the time Vdd reaches its rated minimum value
www.sitime.com
SiT2025B High Frequency, Automotive AEC-Q100 SOT23 Oscillator
Table 1. Electrical Characteristics (continued)
Parameters
Symbol
Min.
Typ.
Max.
Unit
Condition
Jitter
T_jitt
RMS Period Jitter
T_phj
RMS Phase Jitter (random)
1.6
2.5
ps
f = 125 MHz, 2.25V to 3.63V
1.8
3
ps
f = 125 MHz, 1.8V
0.7
ps
f = 125 MHz, Integration bandwidth = 900 kHz to 7.5 MHz
1.5
ps
f = 125 MHz, Integration bandwidth = 12 kHz to 20 MHz
Table 2. Pin Description
Top View
Symbol
Functionality
1
GND
Power
2
NC
No Connect
Output Enable
3
OE/NC
No Connect
Electrical ground[1]
GND
1
NC
2
OE/NC
3
YXXXX
Pin
No connect
H[2]: specified frequency output
L: output is high impedance. Only output driver is disabled.
Any voltage between 0 and Vdd or Open[2]: Specified
frequency output. Pin 3 has no function.
5
OUT
4
VDD
[1]
4
VDD
Power
Power supply voltage
5
OUT
Output
Oscillator output
Figure 1. Pin Assignments
Notes:
1. A capacitor of value 0.1 µF or higher between Vdd and GND is required.
2. In OE or ST mode, a pull-up resistor of 10 kΩ or less is recommended if pin 3 is not externally driven. If pin 3 needs to be left floating, use the NC option.
Table 3. Absolute Maximum Limits
Attempted operation outside the absolute maximum ratings may cause permanent damage to the part. Actual performance
of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings.
Min.
Max.
Unit
Storage Temperature
Parameter
-65
150
°C
Vdd
-0.5
4
V
Electrostatic Discharge
2000
V
Soldering Temperature (follow standard Pb free soldering guidelines)
260
°C
Junction Temperature[3]
150
°C
Note:
3. Exceeding this temperature for extended period of time may damage the device.
Table 4. Thermal Consideration[4]
Package
SOT23-5
θJA, 4 Layer Board
θJC, Bottom
(°C/W)
(°C/W)
421
175
Note:
4. Refer to JESD51 for θJA and θJC definitions, and reference layout used to determine the θJA and θJC values in the above table.
Table 5. Maximum Operating Junction Temperature[5]
Max Operating Temperature (ambient)
85°C
95°C
105°C
115°C
125°C
135°C
Note:
5. Datasheet specifications are not guaranteed if junction temperature exceeds the maximum operating junction temperature.
Table 6. Environmental Compliance
Parameter
Condition/Test Method
Mechanical Shock
MIL-STD-883F, Method 2002
Mechanical Vibration
MIL-STD-883F, Method 2007
Temperature Cycle
JESD22, Method A104
Solderability
MIL-STD-883F, Method 2003
Moisture Sensitivity Level
MSL1 @ 260°C
Rev. 1.7
Page 2 of 15
www.sitime.com
Test Circuit and Waveform
Vout
Test
Point
Vdd
tr
15 pF
(including probe
and fixture
capacitance)
80% Vdd
4
5
1
2
tf
Power
Supply
0.1µF
3
50%
20% Vdd
High Pulse
(TH)
Period
Vdd
1k
Low Pulse
(TL)
OE/ST Function
Figure 3. Waveform[6]
Figure 2. Test Circuit[6]
Note:
6. SiT2025 has “no runt” pulses and “no glitch” output during startup or resume.
Timing Diagrams
Vdd
90% Vdd
Vdd
50% Vdd
T_oe
T_start
Pin 4 Voltage
OE Voltage
No Glitch
during start up
CLK Output
CLK Output
HZ
HZ
T_oe: Time to re-enable the clock output
T_start: Time to start from power-off
Figure 4. Startup Timing (OE Mode)[7]
Figure 5. OE Enable Timing (OE Mode Only)
Vdd
OE Voltage
50% Vdd
T_oe
CLK Output
HZ
T_oe: Time to put the output in High Z mode
Figure 6. OE Disable Timing (OE Mode Only)
Note:
7. SiT2025 has “no runt” pulses and “no glitch” output during startup or resume.
Rev. 1.7
Page 3 of 15
www.sitime.com
Performance Plots[8]
1.8
2.5
2.8
3.0
3.3
DUT1
DUT2
DUT3
DUT4
DUT5
DUT6
DUT7
6.5
DUT8
DUT9
DUT10
DUT11
DUT12
DUT13
DUT14
6.3
DUT15
DUT16
DUT17
DUT18
DUT19
DUT20
25
6.1
Frequency (ppm)
Idd (mA)
5.9
5.7
5.5
5.3
5.1
4.9
10
5
-10
-15
4.7
-20
4.5
-25
115
117
119
121
123
125
127
129
131
133
135
-55
137
-35
-15
5
Frequency (MHz)
2.8 V
3.3 V
3.0 V
1.8 V
4.0
55
3.5
54
2.5
2.0
1.5
105
125
2.5 V
2.8 V
3.0 V
3.3 V
52
51
50
49
48
47
46
45
0.0
115
117
119
121
123
125
127
129
131
133
135
115
137
117
119
121
123
Figure 9. RMS Period Jitter vs Frequency
1.8 V
2.5 V
2.8 V
125
127
129
131
133
135
137
Frequency (MHz)
Frequency (MHz)
Figure 10. Duty Cycle vs Frequency
1.8 V
3.3 V
3.0 V
2.5
2.5
2.0
2.0
Fall time (ns)
Rise time (ns)
85
1.0
0.5
1.5
1.0
0.5
2.5 V
2.8 V
3.0 V
3.3 V
1.5
1.0
0.5
0.0
0.0
-40
-30
-20
-10
40
50
60
70
80
90
100 110 120
-40
Temperature (°C)
-30
-20
-10
40
50
60
70
80
90
100 110 120
Temperature (°C)
Figure 12. 20%-80% Fall Time vs Temperature
Figure 11. 20%-80% Rise Time vs Temperature
Rev. 1.7
65
53
3.0
Duty cycle (%)
RMS period jitter (ps)
2.5 V
45
Figure 8. Frequency vs Temperature
Figure 7. Idd vs Frequency
1.8 V
25
Temperature (°C)
Page 4 of 15
www.sitime.com
2.5 V
1.8 V
2.8 V
3.0 V
3.3 V
1.8 V
2.0
2.5 V
3.0 V
2.8 V
3.3 V
1.0
0.9
1.8
IPJ (ps)
IPJ (ps)
0.8
1.6
1.4
0.7
0.6
1.2
0.5
1.0
115
117
119
121
123
125
127
129
131
133
135
137
Frequency (MHz)
0.4
115
117
119
121
123
125
127
129
131
133
135
137
Frequency (MHz)
Figure 13. RMS Integrated Phase Jitter Random
(12 kHz to 20 MHz) vs Frequency[9]
Figure 14. RMS Integrated Phase Jitter Random
(900 kHz to 20 MHz) vs Frequency[9]
Notes:
8. All plots are measured with 15 pF load at room temperature, unless otherwise stated.
9. Phase noise plots are measured with Agilent E5052B signal source analyzer.
Rev. 1.7
Page 5 of 15
www.sitime.com
Programmable Drive Strength
The SiT2025 includes a programmable drive strength
feature to provide a simple, flexible tool to optimize the
clock rise/fall time for specific applications. Benefits from the
programmable drive strength feature are:
Improves system radiated electromagnetic interference
(EMI) by slowing down the clock rise/fall time.
Improves the downstream clock receiver’s (RX) jitter by
decreasing (speeding up) the clock rise/fall time.
Ability to drive large capacitive loads while maintaining
full swing with sharp edge rates.
For more detailed information about rise/fall time control
and drive strength selection, see the SiTime Application
Notes section.
The SiT2025 can support up to 30 pF in maximum
capacitive loads with up to 3 additional drive strength
settings. Refer to the Rise/Fall Time Tables (Table 7 to 11)
to determine the proper drive strength for the desired
combination of output load vs. rise/fall time.
SiT2025 Drive Strength Selection
Tables 7 through 11 define the rise/fall time for a given
capacitive load and supply voltage.
1. Select the table that matches the SiT2025 nominal
supply voltage (1.8V, 2.5V, 2.8V, 3.0V, 3.3V).
2.
Select the capacitive load column that matches the
application requirement (5 pF to 30 pF)
3.
Under the capacitive load column, select the
desired rise/fall times.
4.
The left-most column represents the part number
code for the corresponding drive strength.
5.
Add the drive strength code to the part number for
ordering purposes.
EMI Reduction by Slowing Rise/Fall Time
Figure 15 shows the harmonic power reduction as the
rise/fall times are increased (slowed down). The rise/fall
times are expressed as a ratio of the clock period. For the
ratio of 0.05, the signal is very close to a square wave. For
the ratio of 0.45, the rise/fall times are very close to neartriangular waveform. These results, for example, show that
the 11th clock harmonic can be reduced by 35 dB if the
rise/fall edge is increased from 5% of the period to 45% of
the period.
Calculating Maximum Frequency
Based on the rise and fall time data given in Tables 7
through 11, the maximum frequency the oscillator can
operate with guaranteed full swing of the output voltage
over temperature as follows:
Max Frequency =
1
5 x Trf_20/80
where Trf_20/80 is the typical value for 20%-80% rise/fall
time.
Example 1
Calculate fMAX for the following condition:
Figure 15. Harmonic EMI reduction as a Function
of Slower Rise/Fall Time
Jitter Reduction with Faster Rise/Fall Time
Power supply noise can be a source of jitter for the
downstream chipset. One way to reduce this jitter is to
speed up the rise/fall time of the input clock. Some chipsets
may also require faster rise/fall time in order to reduce their
sensitivity to this type of jitter. Refer to the Rise/Fall Time
Tables (Table 7 to Table 11) to determine the proper drive
strength.
Vdd = 3.3V (Table 11)
Capacitive Load: 30 pF
Desired Tr/f time = 1.46 ns
(rise/fall time part number code = U)
Part number for the above example:
SiT2025BAE12-18E-137.000000
Drive strength code is inserted here. Default setting is “-”
High Output Load Capability
The rise/fall time of the input clock varies as a function of
the actual capacitive load the clock drives. At any given
drive strength, the rise/fall time becomes slower as the
output load increases. As an example, for a 3.3V SiT2025
device with default drive strength setting, the typical rise/fall
time is 0.46 ns for 5 pF output load. The typical rise/fall time
slows down to 1 ns when the output load increases to
15 pF. One can choose to speed up the rise/fall time to
0.72 ns by then increasing the driven strength setting on the
SiT2025 to “F”.
Rev. 1.7
Page 6 of 15
www.sitime.com
Rise/Fall Time (20% to 80%) vs CLOAD Tables
Table 7. Vdd = 1.8V Rise/Fall Times
for Specific CLOAD
Table 8. Vdd = 2.5V Rise/Fall Times
for Specific CLOAD
Rise/Fall Time Typ (ns)
Drive Strength \ CLOAD
5 pF
15 pF
5 pF
15 pF
T
0.93
n/a
R
1.45
n/a
E
0.78
n/a
B
1.09
n/a
U
0.70
1.48
T or "-": default
0.62
1.28
F or "-": default
0.65
1.30
E
0.54
1.00
U
0.43
0.96
F
0.34
0.88
Table 9. Vdd = 2.8V Rise/Fall Times
for Specific CLOAD
Table 10. Vdd = 3.0V Rise/Fall Times
for Specific CLOAD
5 pF
15 pF
30 pF
5 pF
15 pF
30 pF
R
1.29
n/a
n/a
R
1.22
n/a
n/a
B
0.97
n/a
n/a
B
0.89
n/a
n/a
T or "-": default
0.55
1.12
n/a
T or "-": default
0.51
1.00
n/a
E
0.44
1.00
n/a
E
0.38
0.92
n/a
U
0.34
0.88
n/a
U
0.30
0.83
n/a
F
0.29
0.81
1.48
F
0.27
0.76
1.39
Table 11. Vdd = 3.3V Rise/Fall Times
for Specific CLOAD
5 pF
15 pF
30 pF
R
1.16
n/a
n/a
B
0.81
n/a
n/a
T or "-": default
0.46
1.00
n/a
E
0.33
0.87
n/a
U
0.28
0.79
1.46
F
0.25
0.72
1.31
Note:
10. “n/a” indicates that the resulting rise/fall time from the respective combination of the drive strength and output load does not provide rail-to-rail swing and is
not available.
Rev. 1.7
Page 7 of 15
www.sitime.com
Pin 1 Configuration Options (OE or NC)
Pin 1 of the SiT2025 can be factory-programmed to support
two modes: Output Enable (OE) or No Connect (NC).
These modes can also be programmed with the
Time Machine II using Field Programmable Oscillators.
In addition, the SiT2025 supports “no runt” pulses and
“no glitch” output during startup or when the output
driver is reenabled from the OE disable mode as shown
in the waveform captures in Figure 16 and Figure 17.
Output Enable (OE) Mode
In the OE mode, applying logic low to the OE pin only
disables the output driver and puts it in Hi-Z mode. The core
of the device continues to operate normally. Power
consumption is reduced due to the inactivity of the output.
When the OE pin is pulled High, the output is typically
enabled in
