WTL5G60392VH
WTL5G60392VH
    WTL(维拓)
    SMD-2
    无源晶振 18pF 12MHz ±30ppm 60Ω -20℃~+70℃ SMD-2
WTL5G60392VH 数据手册
Quartz Crystal, Series TG5 SMD Glass Sealed Ceramic 5.0×3.2×1.2 mm Feature 2 pads SMD glass sealed crystal units Highreliable environmental performance Tight tolerance and stability parts are available Designed for automatic mounting and reflow soldering Contains Pb in sealing glass exempted by RoHS directive Electrical Specifications Item Specifications Frequency Range 8~12 Mode AT/Fundamental Load Capacitance (CL) 10pF, 20pF, 30pF, 32pF or Specify Frequency Tolerance( at 25°C ) ±10ppm ~ ±30ppm or specify Operating Temperature Range -20~+70°C or Specify Frequency Stability Over Operating Temperature Range ±10ppm ~ ±30ppm or specify Equivalent Series Resistance (ESR) max. 12~54 60Ω 40~80 AT/3RD 40Ω Storage Temperature Range -55~+125°C Shunt Capacitance( C 0 ) 5pF Max Drive Level (Typical) 1~200μW (100μW typical) Aging @25°C 1st Year (Max) ±3 ppm/year 100Ω Dimension(mm) Connection 0.5 1.2 ± 0.15 3.2 ± 0.15 5.0 ± 0.15 Suggested Layout 2.4 2.0 09 http://www.wtlcrystals.com 2.0 1.7 2.4 1.7 Email:wtl@wtlcrystals.com Tel:86-755-82677582
WTL5G60392VH 价格&库存
很抱歉,暂时无法提供与“WTL5G60392VH”相匹配的价格&库存,您可以联系我们找货
