QT1M-32.768KDZF-T
QT1M-32.768KDZF-T
    QST(矽睿)
    SMD-2
    无源晶振 12.5pF 65KΩ ±20ppm -40℃~+85℃ SMD-2 32.768KHz
QT1M-32.768KDZF-T 数据手册
QT1M kHz Crystal Fuel The Digital World Features ● ● ● ● Applications Frequency range : 32.768 kHz SMD : Plastic package External dimensions (mm) L : 6.9 x W : 1.4 x H : 1.4 RoHS compliant Contains Pb, exempted by RoHS directive ● Small mobile devices Consumer products Electrical Characteristics Item Symbol QT1M f0 32.768 kHz ∆f/f0 ±20 ppm CL 7pF, 9pF, 12.5pF Operating Temperature Range TOTR -40°C ~ +85°C Storage Temperature Range TSTR -55°C ~ +125°C TM 25°C ± 5°C Temperature Coefficient β -0.04ppm/°C2 Max. Motional Capacitance C1 1.9 fF Typ. Motional Resistance (ESR) R1 65 kΩ Max. Drive Level DL 1 μW Max. ∆f/f0 ±3 ppm Max. C0 0.8 pF Typ. Nominal Frequency Frequency Tolerance Load Capacitance Turnover Temperature Aging Shunt Capacitance Conditions at 25°C at 25°C at 25°C ± 3°C,first year Dimensions Internal Connection The tilted cut is the INDEX MARK. Do not connect pin2 & pin3 to external device. (Unit: mm) Rev. 1.03 Page 1 www.qstproducts.com QT1M kHz Crystal Fuel The Digital World Ordering Information QT1M - 32.768K - D Z F - T Frequency Tolerance (at 25°C) D ± 20 ppm Packaging Method T Tape & Reel Load Capacitance Frequency Stability (over Temp.) Z Standard for kHz Y C F 7 pF 9 pF 12.5 pF Packing (Unit: mm) Reflow Profile Total time : Max. 200 sec. Solder melting point : 220°C Rev. 1.03 Page 2 www.qstproducts.com
QT1M-32.768KDZF-T 价格&库存
很抱歉,暂时无法提供与“QT1M-32.768KDZF-T”相匹配的价格&库存,您可以联系我们找货
QT1M-32.768KDZF-T
  • 1000+1.58948
QT1M-32.768KDZF-T
  • 1+3.668361+0.47460
  • 10+2.6552010+0.34352
  • 50+1.9040650+0.24634
  • 100+1.88659100+0.24408
库存:2361
QT1M-32.768KDZF-T
  • 1000+1.711901000+0.22148
QT1M-32.768KDZF-T
  • 1+3.534151+0.45724
  • 10+3.0462110+0.39411
  • 25+2.8785725+0.37242
  • 50+2.7602750+0.35712
  • 100+2.64538100+0.34225
  • 250+2.50167250+0.32366
  • 500+2.39834500+0.31029
  • 1000+2.299101000+0.29745
库存:5910
QT1M-32.768KDZF-T
  • 3000+2.150143000+0.27818
  • 6000+2.061226000+0.26668
  • 9000+2.010969000+0.26017
  • 15000+1.9493615000+0.25221
  • 21000+1.9098421000+0.24709
  • 30000+1.8688530000+0.24179
库存:5910
