XXACCLNANF-48.000000 数据手册
XX Type
3.2 x 2.5 mm SMD Crystal
Actual Size
FEATURE
- Typical 3.2 x 2.5 x 0.7 mm ultra thin ceramic package.
- 8mm width Tape & Reel package for automatic assembly.
- Tight tolerance 10 ppm available.
TYPICAL APPLICATION
- Automotive
- Bluetooth, Mobile Phone, GPS
- Wireless LAN, 4G/LTE
- Hard Disk
RoHS Compliant
XX
DIMENSION (mm)
SOLDER PAD L AYOUT (mm)
[ T O P V IE W ]
0.70±0.20
[ S ID E V IE W ]
[ B O T T O M V IE W ]
#4
#3
#1
#2
1.2
1.1
2.50±0.20
GND
GND
1.6
3.20±0.20
#2 and #4 are connected to the cover
(please connect to ground)
#4
0.90±0.10
#3
2.2
0.90±0.10
1.50±0.10
2.10±0.10
#1
#2
ELECTRICAL SPECIFICATION
Parameter
Min.
Storage Temp. Range
Standard Frequency
Level of Drive
Shunt Capacitance (Co)
Insulation Resistance
Aging
Typical
-55
500 MΩ@ DC100V
Max.
16, 24, 26, 27, 32, 40
10
±1.0 to ±3.0
Unit
125
200
3.0
MHz
µw
pF
ppm / year
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position.
EQUIVALENT SERIES RESISTANCE (E. S. R.)
Frequency Range
12 MHz Fo
13 MHz < Fo
19.5 MHz < Fo
27 MHz < Fo
13 MHz
19.5 MHz
27 MHz
60 MHz
FREQ. STABILITY vs. TEMP. RANGE
Temp. ( o C)
ppm
±5
±10
±15
MODE
E.S.R
A1
A1
A1
A1
XXACCLNANF-48.000000 价格&库存
很抱歉,暂时无法提供与“XXACCLNANF-48.000000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4.409351+0.56600
- 10+3.8755310+0.49747
- 25+3.6624325+0.47012
- 50+3.5104050+0.45060
- 100+3.36563100+0.43202
- 250+3.18233250+0.40849
- 500+3.05076500+0.39160
- 1000+2.924511000+0.37540
- 国内价格 香港价格
- 3000+2.735153000+0.35109
- 6000+2.622096000+0.33658
- 9000+2.558169000+0.32837
- 15000+2.4798515000+0.31832
- 21000+2.4296121000+0.31187
- 30000+2.3774930000+0.30518
