S11810T-27.000-X1-R
S11810T-27.000-X1-R
    AKER(安碁科技)
    SMD2016_4P
    有源晶振 27.000000MHz 1.8V -40℃~+125℃ HCMOS
S11810T-27.000-X1-R 数据手册
RoHS Compliant Pb - Lead Free Ltr Revisions Date Appr Electrical Specifications: Frequency Range Temperature Stability Aging per Year Standard Extended Operating Temperature Range Storage Temperature Range Supply Voltage Input Current Output Voltage Output Symmetry (Duty Cycle) Output Load Output Level Phase Jitter (12 KHz to 20 MHz) Rise and Fall Time Standby Function Start Up Time 4.000 to 10.000 MHz 10.100 to 20.000 MHz 20.100 to 32.000 MHz 32.100 to 50.000 MHz Logic High (Voh) Logic Low (Vol) Standard 4.000 to 50.000 MHz ±100 ±50 PPM Max ±25 ±3 -10 to +70 -40 to +85 ºC -55 to +125 +1.8 ± 5% +2.5 ± 5% +3.3 ± 10% Vdd 3 4 5 4 5 6 mA Max 5 6 7 6 7 8 90% Vdd Min 10% Vdd Max 40 to 60 % 15 pF CMOS 1 ps Max RMS 6 ns Max Tri-State 10 ms Max Temperature stability is Inclusive of all conditions: Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage, supply voltage change, output load changes, shock, vilbration, and 1st year aging at +25°C. Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: Oct. 29, 2013 Clock Oscillator Ultra Miniature 2.0 x 1.6 millimeter Surface Mount General Product Specification Part Number: S1 Series www.aker-usa.com Mechanical Outline: Pin1 INH High or Open Low Pin 3 Output Operating High Impedance Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Page: 2/4 Date: Oct. 29, 2013 P/N: www.aker-usa.com S1 Series Carrier Tape Dimensions: Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date: Oct. 29, 2013 P/N: www.aker-usa.com S1 Series How to build a Part Number: Series Package S 1 Parameter 2.0 x 1.6 mm Supply Voltage 33 25 18 +3.3 Vdd ± 10% +2.5 Vdd ± 5% +1.8 Vdd ± 5% Temperature Stability 10 05 025 ±100 PPM ±50 PPM ±25 PPM See Notes 40 to 60% Duty Cycle Frequency 4.000 to 50.000 MHz - Temperature Range See Notes X -10 to +70 ºC -40 to +85 ºC - Packaging R Tape and Reel Part Number Example: S12505-18.432-X-R S1: 2.0 x 1.6 mm SMD Package 25: +2.5 Vdd Supply Voltage 05: ±50 PPM Temperature Stability 18.432 MHz Nominal Frequency X: -40 to + 85° C Extended Temperature Range R: Tape and Reel Packaging Notes: 1- Standard Duty Cycle and Temperature Range do not need to be included in Part Number description. 2- Product is shipped in Tape and Reel configuration. Each reel contains 1000 pieces. 3- Specification subject to change without notice. Page: 4/4 Date: Oct. 29, 2013 P/N: www.aker-usa.com S1 Series
S11810T-27.000-X1-R
1. 物料型号:S1系列 2. 器件简介:超小型表面贴装时钟振荡器,尺寸为2.0 x 1.6毫米。 3. 引脚分配: - Pin 1: Enable/Disable - Pin 2: 地 - Pin 3: 输出 - Pin 4: Vdc 4. 参数特性: - 频率范围:4.000至50.000 MHz - 温度稳定性:±50 PPM - 老化率:每年±3 PPM - 工作温度范围:标准 -10至+70℃,扩展 -40至+85℃ - 供电电压:+1.8V至+3.3V - 输入电流:在不同频率范围内从3μA至8μA不等 - 输出电压:高电平至少90% Vdd,低电平至多10% Vdd - 输出负载:15 pF - 相位抖动:12 kHz至20 MHz时最大1 ps RMS - 上升和下降时间:最大6 ns - 待机功能:三态 - 启动时间:最大10 ms 5. 功能详解:包括温度稳定性涵盖所有条件,如校准容差、频率稳定性、供电电压变化等。 6. 应用信息:文档未明确提供应用信息,但从参数特性可推断适用于需要小型化和高精度时钟源的场合。 7. 封装信息:采用密封陶瓷金属封装,详细尺寸和标记信息已给出。
S11810T-27.000-X1-R 价格&库存
很抱歉,暂时无法提供与“S11810T-27.000-X1-R”相匹配的价格&库存,您可以联系我们找货
