LFSPXO073700REEL
LFSPXO073700REEL
    IQD
    SMD2016_4P
    有源晶振 32.768kHz3.3V -40℃~+85℃ CMOS
LFSPXO073700REEL 数据手册
Crystal Clock Oscillator Specification Part No. + Packaging: LFSPXO073700Reel Customer Part: Description 32.768kHz miniature 2 x 1.6mm crystal oscillator in an hermetically sealed ceramic package with a seam sealed metal lid. Model IQXO-402 Model Issue number 3 Frequency Parameters Frequency 32.7680kHz Frequency Stability ±30.00ppm Operating Temperature Range Ageing -40.00 to 85.00°C ±3ppm max per year @ 25°C Electrical Parameters Supply Voltage Current Draw 3.3V ±10% 0.200mA Outline (mm) Output Details Output Compatibility Drive Capability Rise and Fall Time Duty Cycle CMOS 15pF 100.0ns max 40/60% Output Control Standby Operation: Logic ‘1’ (≥70%Vs) to pad 1 enables oscillator output Logic ‘0’ (≤30%VS) to pad 1 disables oscillator output; when disabled the oscillator output goes to the high impedance state. No connection to pad 1 enables oscillator output. Standby Current: 10μA max @ -40 to 85°C 20μA max @ -40 to 125°C Start-up Time: 10ms max 0.3ms typ to 90% of final amplitude (under ideal conditions @ 25°C) Environmental Parameters Storage Temperature Range: –55 to 125°C Shock : 1500G, 0.5ms, 3 times for each surface, total 18 times. Vibration: Frequency range: 20~2000Hz, peak to peak amplitude 1.52mm, peak acceleration:20G (196m/s2), 3 directions (X, Y,Z), each cycle: 20min, 4 cycles for each direction. Manufacturing Details RoHS Terminations RoHS Reflow Temp Au over Ni 260°C max for 10s max Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 6 Sep 21 3:57 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 2 Crystal Clock Oscillator Specification Part No. + Packaging: LFSPXO073700Reel Customer Part: Packaging Details Pack Style: Reel Pack Size: 3,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 6 Sep 21 3:57 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 2 of 2
LFSPXO073700REEL
1. 物料型号:ATMEGA16U2-AU 2. 器件简介:ATMEGA16U2-AU是一款低功耗、高性能的8位AVR增强型微控制器,具有16KB的系统内可编程Flash、1KB的EEPROM、512字节的SRAM和32个通用I/O引脚。 3. 引脚分配:ATMEGA16U2-AU共有32个引脚,包括电源引脚、地引脚、复位引脚、I/O引脚等。 4. 参数特性:工作电压范围1.8-5.5V,工作频率12MHz,内置RC振荡器,具备JTAG接口和USB接口。 5. 功能详解:ATMEGA16U2-AU具备多种功能,包括定时器、串行通信接口、模数转换器等。 6. 应用信息:广泛应用于计算机外设、工业控制、医疗设备等领域。 7. 封装信息:TQFP44封装,尺寸为10mm x 10mm。
LFSPXO073700REEL 价格&库存
很抱歉,暂时无法提供与“LFSPXO073700REEL”相匹配的价格&库存,您可以联系我们找货
