LFXTAL068297REEL
LFXTAL068297REEL
    IQD
    SMD2520_4P
    无源晶振 16MHz ±10ppm 8pF 100Ω -20℃~+75℃
LFXTAL068297REEL 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL068297Reel Customer Part: Description 2.5 x 2mm SMD crystal in a hermetically sealed ceramic package with a seam sealed metal lid. Model CFPX-218 Model Issue number 4 Frequency Parameters Frequency 16.0MHz Frequency Tolerance Tolerance Condition Frequency Stability ±10.00ppm @ 25°C ±10.00ppm Operating Temperature Range -20.00 to 75.00°C Overtone Order Ageing Fundamental ±3ppm max per year @ 25°C Electrical Parameters Outline (mm) 8.00pF 5pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 100µW max 100.00Ω max Environmental Parameters Storage Temperature Range: -55 to 125°C Drop: 100cm drop (3 times) onto hard wooden board. Vibration: MIL-STD-883F, Method 2007.3: 20G (20Hz-2000Hz), 1.52mm amplitude, 20mins in 3 mutually perpendicular planes (total 4hrs). Manufacturing Details Maximum Process Temperature: 260°C (10secs max) RoHS Terminations NiAu RoHS Reflow Temp 260°C max for 10secs max Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 1,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 6 Dec 21 15:35 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL068297REEL
物料型号为LFXTAL068297Reel,封装为2.5 x 2mm SMD晶体,采用密封陶瓷封装和密封金属盖。
以下是该物料的详细信息:
- 器件简介:2.5 x 2mm SMD晶体,密封陶瓷封装,密封金属盖。
- 引脚分配:1. Crystal Pad Connections,2. GND,3. Crystal,4. GND。
- 参数特性: - 频率:16.0MHz - 频率容差:±10.00ppm(在25°C时) - 频率稳定性:±10.00ppm - 负载电容(CL):8.00pF - 并联电容(C0):最大5pF - 驱动电平:最大100µW - ESR(等效串联电阻):最大100.00Ω - 功能详解: - 基频模式 - 老化:每年在25°C时最大±3ppm - 应用信息:适用于需要高精度和高稳定性的应用。
- 封装信息: - 封装尺寸:2.5 x 2mm - 封装类型:SMD - 包装方式:卷装,符合EIA-481-D标准 - 包装尺寸:1,000 - 符合RoHS指令(2015/863/EU)和REACH法规 - 最大工艺温度:260°C(最多10秒) - 回流温度:NiAu,最多260°C,最多10秒 - MSL等级:不适用
请注意,这些信息是从PDF文档中提取的,可能需要进一步的验证和详细说明。
LFXTAL068297REEL 价格&库存
很抱歉,暂时无法提供与“LFXTAL068297REEL”相匹配的价格&库存,您可以联系我们找货
