6U-52.000MCE-T
6U-52.000MCE-T
    TXC(台晶)
    SMD-6
    有源晶振 52MHz 2.5V SMD-6
6U-52.000MCE-T 数据手册
Think of Frequency Think of Oscillators Series SMD Voltage Controlled Crystal Oscillators 7.0 x 5.0 x 1.3 mm 6U Series come visit our site http://www.txccorp.com Features .Voltage Controlled Crystal Oscillator (VCXO). .Fundamental solution. .CMOS output, output frequencies 1 MHz to 59 MHz. .Wide pull range and good linearity. .Excellent low phase noise and jitter. .Tri-State function available. .Supply Voltage Range : 3.3 V , 5 V. .Main applications : ADSL, Set-top Box, and BS. .RoHS Compliant / Pb Free. 1 EZ1 28 B C TX 35.3 Electrical Specifications Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Item / Type 6U Output Type CMOS Output Load 15 pF - 30 pF Oscillation Mode Fundamental Supply Voltage 3.3 V , 5 V Frequency Range 1 ~ 59 MHz Operating Temperature Range - 10 ~ + 70 ℃ , - 40 ~ + 85 ℃ Storage Temperature Range - 55 ~ + 125 ℃ Voltage Vol ( Max.) / Voh ( Min.) 0.1 VDD / 0.9 VDD Rise ( Tr ) / Fall ( Tf ) Time 5 ns Max. Supply Current 45 mA Max. Symmetry 45 ~ 55 % Start-up Time 10 ms Max. Frequency Pulling Range ± 50 , ± 100 ppm , or specify. Nominal Control Voltage 0.5 VDD Control Voltage Range 0 ~ VDD Linearity ± 10 % Max. Phase Jitter ( 12 KHz ~ 20 MHz ) 1 ps Max. Aging ( at 25 ℃ ) ± 3 ppm / year Max * APR=(Pull Range) - (Frequency tolerance at 25 ℃, variation over temperature, supply voltage variation, and aging.) Dimensions Units: mm 80
6U-52.000MCE-T 价格&库存
很抱歉,暂时无法提供与“6U-52.000MCE-T”相匹配的价格&库存,您可以联系我们找货
