S7A3305-156.250-P-X-R
    AKER(安碁科技)
    SMD7050_6P
    有源晶振 156.250000 MHz 2.5V -40℃~+85℃ LVPECL
S7A3305-156.250-P-X-R 数据手册
RoHS Compliant Pb - Lead Free Ltr Re Appr Date isions Electrical Specifications: Frequency Range 13.500 - 160.000 ±100 ±50 ±25 ±3 -20 to +70 -40 to +85 -40 to +125 -55 to +125 Frequency Stability over Temperature Aging per Year Standard Extended Automotive Operating Temperature Range Storage Temperature Range Supply Voltage Input Current Output Voltage 13.500 - 160.000Mhz Logic High (Voh) Logic Low (Vol) PPM Max ºC 3.3 ± 5% 70 2.275 1.68 45 to 55 LVPECL - Complimentary Output 50 Output Symmetry Output Type Output Load Rise and Fall Time 2.5 ± 5% 70 1.475 1.095 MHz 13.500 - 99.999Mhz 100.000 - 160.000Mhz 1 0.5 Enable-Disable Function Enable High Input Voltage Enable Low Input Voltage Phase Jitter (12 KHz to 20 MHz) 1 Ω 1 0.5 ns Max Q Pin 4 - QN Pin 5 Operating High Impedance 2.31 0.99 Vdd Min Vdd Max ps RMS Tri-State INH - Pin 1 High - Pin 1 Low - Pin 1 1.75 0.75 Vdd mA Max Vdd Min Vdd Max % - Temperature stability is Inclusive of all conditions: Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage, supply voltage change, output load changes, shock, vilbration, and 1st year aging at +25°C. Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR Re iew: EG MK Appr: 1/4 Page: Date: Sept 6, 2014 Clock Oscillator LVPECL - Complimentary Output 5.0 x 7.0 mm Surface Mount - 6 Pad General Product Specification Part Number: S7A LVPECL Series www.aker-usa.com Solder Pattern: Mechanical Outline: C1: 0.01 uF or 0.1 uF decoupling capacitor is recommended. C2: By-Pass capacitor for noise suppression. Contact Aker for suggested values. *Package Height: 1.4 mm Max for 13.500 to 160.000 MHz Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Pad Connection: Pin Connection 1- INH 2- NC 3- GND 4- Output - Q 5- Comp. Output - QN 6- Vdd Top View Page: 2/4 Date: Sept 6, 2014 P/N: S7A LVPECL Series .w aker-usa.com AKER AKER +0.1 1.7 -0.0 AKER AKER A A B 8.0 ¡ Ó0.1 Ko:2.0 Ao:5.4 5¢X(max) Dimensions are millimeters. A-A SECTION Solder Reflow Characteristics: Page: 3/4 B-B SECTION Pin #1 5¢X(max) 7.5 ¡ Ó0.1 B 0.3 ¡ Ó0.05 Bo:7.9 4.0 ¡ Ó0.1 16.0 ¡ Ó0.3 +0.1 1.5 -0.0 2.0 ¡ Ó0.1 1.75 ¡ Ó0.1 Carrier Tape Dimensions: Date: Sept 7, 2014 P/N: S7A LVPECL Series www.aker-usa.com How to build a Part Number: Series Package S 7A Parameter 7.0 x 5.0 mm - 6 Pad Supply Voltage 25 33 +2.5 Vdd ± 5% +3.3 Vdd ± 5% Temperature Stability 10 05 025 ±100 PPM ±50 PPM ±25 PPM Frequency Output Load Temperature Range Packaging 13.500 - 160.000 P See Notes X X1 M R - MHz - - LVPECL -20 to +70 ºC -40 to +85 ºC -40 to +125 ºC 250pcs Ree1 1000pcs Reel Part Number Example: S7A3305-156.250-P-X-R S7A: 5.0 x 7.0 mm SMD Package - 6 Pad 33: +3.3 Vdd Supply Voltage 05: ±50 PPM Temperature Stability 156.250 MHz Nominal Frequency P: LVPECL Output X: -40 to + 85° C Extended Temperature Range R: Tape and Reel Packaging - 1000pcs Reel Notes: 1- Standard Temperature Range does not need to be included in Part Number description. *25PPM not available in X1 temp range 2- Product is shipped in Tape and Reel configuration. 3- Quantities less than 250pcs are shipped in tape. 4- Specification subject to change without notice. Page: 4/4 Date: Sept 6, 2014 P/N: S7A LVPECL Series www.aker-usa.com
1. 物料型号:S7A LVPECL系列 2. 器件简介:文档提供了时钟振荡器的电气规格和机械外形尺寸。 3. 引脚分配:文档中列出了6个引脚的连接方式,包括INH(抑制)、NC(无连接)、GND(地)、Output - Q(输出)、Comp. Output - QN(互补输出)和Vdd(供电)。 4. 参数特性: - 频率范围:13.500-160.000 MHz - 频率稳定性:±100 PPM Max(标准)、±50 PPM、±25 PPM - 老化率:±3 PPM每年 - 工作温度范围:标准 -20到+70°C,扩展 -40到+85°C,汽车 -40到+125°C - 存储温度范围:-55到+125°C - 供电电压:2.5±5% Vdd 或 3.3±5% Vdd - 输入电流:最大70 mA(在13.500-160.000MHz) - 输出电压:逻辑高1.475-2.275 Vdd Min,逻辑低1.095-1.68 Vdd Max - 输出对称性:45%-55% - 输出类型:LVPECL - 互补输出 - 输出负载:50 pF - 上升和下降时间:在13.500-99.999MHz为1ns Max,100.000-160.000MHz为0.5ns Max 5. 功能详解:包括使能-禁用功能,高/低电平操作,以及相位抖动规格。 6. 应用信息:适用于需要精确时钟信号的应用,如通信设备。 7. 封装信息:5.0 x 7.0 mm表面贴装封装,6个焊盘。
S7A3305-156.250-P-X-R 价格&库存
很抱歉,暂时无法提供与“S7A3305-156.250-P-X-R”相匹配的价格&库存,您可以联系我们找货
