TSMV3-H25CQ33RC-27.000M
    TRANSKO
    SMD-4
    有源晶振 27MHz 3.3V SMD-4
TSMV3-H25CQ33RC-27.000M 数据手册
TSMV3 RoHS Compliant CMOS MINIATURE SMD VCXO (3.2 x 2.5 x 1.2mm) FEATURES:  SMALLEST PACKAGE VCXO   WIDE FREQUENCY RANGE EXCELLENT HEAT RESISTANCE / HIGH STABILITY ■ SPECIFICATION PARAMETER FREQUENCY RANGE FREQUENCY STABILITY OPERATING TEMPERATURE RANGE STORAGE TEMPERATURE RANGE SUPPLY VOLTAGE ±10% SUPPLY CURRENT LOGIC FAMILY LOAD LEVEL LOGIC ‘1’ (VOH) OUTPUT LEVEL LOGIC ‘0’ (VOL) SYMMETRY (DUTY CYCLE) RISE AND FALL TIME (Tr/Tf) START-UP TIME FREQUENCY DEVIATION CONTROL VOLTAGE SLOPE LINEARITY MODULATION BANDWIDTH @-3dB INPUT IMPEDANCE AGING @ 25°C + 3°C PHASE JITTER RMS PHASE NOISE ■ PACKAGE DIMENSIONS MIN. 1.25 ±10* -40 -55 1.8 TYP. MAX. 70 ±100 85 125 3.3 15 UNIT MHz ppm °C °C V mA NOTE *Available in selected operation temp. See P/N guide for other options See P/N guide for other options HCMOS 15pF 0.9 x VDD 40 50 ±50 0 V V % nS mS ppm V 0.1 x VDD 60 5 5 1/2 VDD Positive VDD ±15 See P/N guide for other options See P/N guide for other options % kHz kΩ ppm @ for 1st year pS @ 12kHz ~ 20MHz offset dBc/Hz @1kHz offset 10 100 ±3 1.0 -120 ■ SOLDER PATTERN ■ REFLOW PROFILE Soldering 1.4 TOP * 150 ±5°C Unit : mm 2.2 1 Pre-heating
TSMV3-H25CQ33RC-27.000M 价格&库存
很抱歉,暂时无法提供与“TSMV3-H25CQ33RC-27.000M”相匹配的价格&库存,您可以联系我们找货
