TXETDHSANF-32.000000
    TAITIEN(泰艺)
    SMD-4
    有源晶振 32MHz 2.8V~3.3V SMD-4
TXETDHSANF-32.000000 数据手册
TX Type 3.2 x 2.5 mm SMD Voltage Controlled Temperature ature Compensated Crystal Oscillator Actual Size FEATURE - Typical 3.2 x 2.5 x 0.9 mm SMD. - For automatic assembly. - Compactness and lightweight. - Low power consumption. - VCTCXO available. - Low thickness TYPICAL APPLICATION - GPS - WiMAX, WLAN - Mobile Phone RoHS Compliant DIMENSION (mm) SOLDER PAD LAYOUT (mm) [ BOTTOM VIEW ] [ TOP VIEW ] 0.1μF 2.30±0.15 3.20±0.15 1.70±0.15 2.50±0.15 #2 #2 #1 #1 1.80 #4 #3 0.90 #3 0.60±0.10 #4 Pin# 1 0.90±0.10 [ SIDE VIEW ] 0.25±0.04 0.70±0.10 2.40 Function Vcon:VC-TCXO GND / NC:TCXO GND Output VDD 2 3 4 1.00 To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION 3.3 / 3.0 / 2.8 V Parameter Supply Voltage Variation (VDD) Frequency Range Standard Frequency Frequency Tolerance* Frequency stability Vs Supply Voltage (±5%) change Vs Load (±10%) change Vs Aging (@1st year) Supply Current 10 MHz Fo 26 MHz 26 MHz Fo 52 MHz Output Level (Clipped sine wave) Load Control Voltage Range (VCTCXO) Pulling Range (VCTCXO) Vc Input Impedance (VCTCXO) Phase Noise @ 19.2 MHz 1.8 V 2.5 V Min. Max. Min. Max. Min. Max. 2.66 3.465 2.375 2.625 1.71 1.89 10 52 10 52 10 52 10, 12.8, 13, 16.367667, 16.368, 16.369, 19.2, 19.44, 20, 25, 26, 27, 30 30.72, 32, 38.4 _ ±2.0 _ ±2.0 _ ±2.0 _ _ _ _ _ ±0.2 ±0.2 ±1.0 1.5 2.0 _ _ _ _ _ ±0.2 ±0.2 ±1.0 1.5 2.0 _ _ _ _ _ ±0.2 ±0.2 ±1.0 1.5 2.0 _ 100 Hz 1 kHz 10 kHz _ 0.8 10KΩ//10pF 0.5 2.5 _ ±5.0 _ 500 0.8 10KΩ//10pF 0.4 2.4 _ ±5.0 _ 500 0.8 10KΩ//10pF 0.3 1.5 _ ±5.0 _ 500 -115 -135 -148 -115 -135 -148 -115 -135 -148 _ Start time Storage Temp. Range _ _ 2 85 -40 -40 2 85 _ -40 Unit V MHz ppm ppm ppm mA Vp-p V ppm kΩ dBc/Hz 2 85 mSec °C Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. * Frequency at 25°C, 1 hour after reflow. FREQ. STABILITY vs. TEMP. RANGE Temp. (°C) ppm ±0.5 ±1.0 ±1.5 ±2.0 ±2.5 -20 ~ +70 -30 ~ +85 -40 ~ +85 * ○: Available Χ:Conditional X: Not available Note: not all combination of options are available. Other specifications may be available upon request. 6SHFL¿FDWLRQVVXEMHFWWRFKDQJHZLWKRXWQRWLFH www.taitien.com sales@taitien.com.tw Rev(14)01/2020 87
TXETDHSANF-32.000000 价格&库存
很抱歉,暂时无法提供与“TXETDHSANF-32.000000”相匹配的价格&库存,您可以联系我们找货
  • 500+15.38037500+1.98969
