PJM10H10NSQ
PJM10H10NSQ
    PJ(平晶)
    SOT89-3
    MOSFETS SOT89-3 N-Channel VDS=100V VGS=±20V Id=10A RDS(on)=92mΩ
PJM10H10NSQ 数据手册
PJM10H10NSQ N-Channel Enhancement Mode Power MOSFET SOT-89 Features ⚫ Excellent RDS(on) and Low Gate Charge ⚫ VDS= 100V,ID= 10A RDS(on)< 110mΩ @VGS= 10V 1. Gate 2.Drain 3.Source Marking Code: 10H10 Applications Schematic Diagram ⚫ Power Switching Application 2.Drain ⚫ Uninterruptible Power Supply 1.Gate 3.Source Absolute Maximum Ratings Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbol Value Unit Drain-Source Voltage VDS 100 V Gate-Source Voltage VGS ±20 V Drain Current-Continuous ID 10 A Drain Current-Pulsed Note1 IDM 40 A Maximum Power Dissipation PD 1.5 W Junction Temperature TJ 150 °C TSTG -55 to +150 °C RθJA 83 °C/W Storage Temperature Range Thermal Characteristics Thermal Resistance,Junction-to-Ambient Note2 www.pingjingsemi.com Revision:3.0 Feb-2022 1/8 PJM10H10NSQ N-Channel Enhancement Mode Power MOSFET Electrical Characteristics (Ta=25℃ unless otherwise specified) Parameter Symbol Test Condition Min. Typ. Max. Unit Drain-Source Breakdown Voltage V(BR)DSS VGS=0V,ID=250μA 100 -- -- V Zero Gate Voltage Drain Current IDSS VDS=100V,VGS=0V -- -- 1 μA Gate-Body Leakage Current IGSS VGS=±20V,VDS=0V -- -- ±100 nA Gate Threshold Voltage Note3 VGS(th) VDS=VGS,ID=250μA 1 1.5 2.5 V Drain-Source On-Resistance Note3 RDS(on) VGS=10V,ID=5A -- 92 110 mΩ VGS=4.5V,ID=3A -- 99 140 mΩ VDS=5V,ID=8A -- 11 -- S -- 610 -- pF -- 40 -- pF Static Characteristics Forward Transconductance Note3 gFS Dynamic Characteristics Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss -- 25 -- pF Turn-on Delay Time td(on) -- 7 -- nS Turn-on Rise Time tr VDD=30V, ID=10A -- 5 -- nS Turn-off Delay Time td(off) VGS=10V,RG=1.8Ω -- 16 -- nS VDS=25V,VGS=0V,f=1MHz Switching Characteristics Turn-off Fall Time tf -- 6 -- nS Total Gate Charge Qg -- 12 -- nC Gate-Source Charge Qgs -- 2.2 -- nC Gate-Drain Charge Qgd -- 2.5 -- nC -- -- 1.2 V -- -- 10 A VDS=30V,ID=5A, VGS=10V Source-Drain Diode Characteristics Diode Forward Voltage Note3 VSD Diode Forward Current Note2 IS VGS=0V,IS=6A Note: 1. Repetitive Rating: Pulse width limited by maximum junction temperature. 2. Surface Mounted on FR4 Board, t ≤ 10 sec. 3. Pulse Test: Pulse width≤300μs, duty cycle≤2%. www.pingjingsemi.com Revision:3.0 Feb-2022 2/8 PJM10H10NSQ N-Channel Enhancement Mode Power MOSFET ID Drain Current (A) RDS(on) On-Resistance(mΩ) Typical Characteristic Curves ID Drain Current (A) ID Drain Current (A) Normalized On-Resistance VDS Drain-Source Voltage (V) TJ Junction Temperature(℃) C Capacitance (pF) VDS Drain-Source Voltage (V) VGS Gate-Source Voltage (V) TJ Junction Temperature(℃) www.pingjingsemi.com Revision:3.0 Feb-2022 VDS Drain-Source Voltage (V) 3/8 Is Reverse Drain Current (A) VGS Gate-Source Voltage (V) PJM10H10NSQ N-Channel Enhancement Mode Power MOSFET VSD Source-Drain Voltage (V) r(t),Normalized Effective Transient Thermal Impedance Qg Gate Charge (nC) Square Wave Pluse Duration(sec) www.pingjingsemi.com Revision:3.0 Feb-2022 4/8 PJM10H10NSQ N-Channel Enhancement Mode Power MOSFET Package Outline SOT-89 Dimensions in mm Ordering Information Device Package PJM10H10NSQ SOT-89 www.pingjingsemi.com Revision:3.0 Feb-2022 Shipping 1,000PCS/Reel&7inches 3,000PCS/Reel&13inches 5/8 PJM10H10NSQ N-Channel Enhancement Mode Power MOSFET Conditions of Soldering and Storage  Recommended condition of reflow soldering Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust the following parameters:  Time length of peak temperature (longer)  Time length of soldering (longer)  Thickness of solder paste (thicker)  Conditions of hand soldering  Temperature: 370 OC  Time: 3s max.  Times: one time   Storage conditions Temperature 5 to 40 OC  Humidity 30 to 80% RH  Recommended period One year after manufacturing www.pingjingsemi.com Revision:3.0 Feb-2022 6/8 PJM10H10NSQ N-Channel Enhancement Mode Power MOSFET Package Specifications  The method of packaging (1,000PCS/Reel&7inches) Cover Tape 1,000 pcs per reel SOT-89 Carrier Tape 8,000 pcs per box 8 reels per box 32,000 pcs per carton 4 boxes per carton  Embossed tape and reel data D A T1 E B G F Reel (7'') www.pingjingsemi.com Revision:3.0 Feb-2022 symbol Value(unit:mm) A Φ179±1 B 60.5±0.2 C 15.3±0.3 D 12.5~13.7 E Φ13.5±0.2 F Φ10.0±0.2 G 2.7±0.2 T1 1.0±0.2 C 7/8 PJM10H10NSQ N-Channel Enhancement Mode Power MOSFET Package Specifications  The method of packaging (3,000PCS/Reel&13inches) 3,000 pcs per reel SOT-89 9,000 pcs per box 3 reels per box 36,000 pcs per carton 4 boxes per carton  Embossed tape and reel data B A T E D F Reel (13'') www.pingjingsemi.com Revision:3.0 Feb-2022 symbol Value(unit:mm) A Φ330±1 B 12.7±0.5 C 16.5±0.3 D Φ99.5±0.5 E Φ13.6±0.3 F 2.8±0.3 T1 1.9±0.2 C 8/8
PJM10H10NSQ 价格&库存
很抱歉,暂时无法提供与“PJM10H10NSQ”相匹配的价格&库存,您可以联系我们找货
PJM10H10NSQ
  • 5+0.41140
  • 20+0.37510
  • 100+0.33880
  • 500+0.30250
  • 1000+0.28556
  • 2000+0.27346
