MMBTSB1198R
MMBTSB1198R
    PJ(平晶)
    SOT-23
    通用三极管 SOT23-3 PNP VCEO=80V VCE(sat)=0.5V Ic=0.5A PD=200mW
MMBTSB1198R 数据手册
MMBTSB1198 PNP Transistor Features  SOT-23 For Switching and AF Amplifier Applications. Equivalent Circuit 1.Base 2.Emitter 3.Collector 3.Collector Marking Code : MMBTSB1198Q : BNQ MMBTSB1198R : BNR 1.Base 2.. Emitter Absolute Maximum Ratings Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbol Value Unit Collector Base Voltage -VCBO 80 V Collector Emitter Voltage -VCEO 80 V Emitter Base Voltage -VEBO 5 V Collector Current -IC 500 mA Maximum Power Dissipation PD 200 mW Junction Temperature TJ 150 ℃ TSTG -55 to +150 ℃ Storage Temperature Range www.pingjingsemi.com Revision:2.0 Mar-2021 1/6 MMBTSB1198 PNP Transistor Electrical Characteristics (TA=25℃) Parameter Symbol Min. Typ. Max. Unit HFE 120 -- 270 -- 180 -- 390 -ICBO -- -- 500 nA -ICEO -- -- 5 μA -IEBO -- -- 500 nA -V(BR)CBO 80 -- -- V -V(BR)CEO 80 -- -- V -V(BR)EBO 5 -- -- V -VCE(sat) -- -- 0.5 V -VBE(sat) -- -- 1.2 V FT -- 180 -- MHz Cob -- 11 -- pF DC Current Gain at VCE = -3 V, IC = -100 mA Gain Group Q R Collector Base Cutoff Current at VCB = -50 V Collector Emitter Cutoff Current at VCE = -64 V Emitter Base Cutoff Current at VEB = -4 V Collector Base Breakdown Voltage at IC = -50 μA Collector Emitter Breakdown Voltage at IC = -2 mA Emitter Base Breakdown Voltage at IE = -50 μA Collector Emitter Saturation Voltage at IC = -500 mA, IB = -50 mA Base Emitter Saturation Voltage at IC = -500 mA, IB = -50 mA Transition Frequency at VCE = -10 V, IC = -50 mA, f = 100 MHz Output Capacitance at VCB = -10 V, f = 1 MHz www.pingjingsemi.com Revision:2.0 Mar-2021 2/6 MMBTSB1198 PNP Transistor Typical Characteristic Curves -250 500 Common Emitter Ta=25℃ Ta=100℃ -1mA hFE -0.9mA -0.8mA -150 DC Current Gain Collector Current IC (mA) -200 VCE=-3V -0.7mA -0.6mA -100 -0.5mA -0.4mA Ta=25℃ 100 -0.3mA -50 -0.2mA -0 IB= -0.1mA -0 -1 -2 -3 Collector-Emitter Voltage -4 10 -5 VCE (V) Ta=100℃ -400 -200 β=10 -1 -10 -500 -100 -100 Ta=100℃ Ta=25℃ -10 β=10 -1 IC (mA) -10 Collector Current -500 -100 IC (mA) 1000 -10 VCE=-3V -0 -200 -400 Base-Emitter Voltage www.pingjingsemi.com Revision:2.0 Mar-2021 -600 VBE (mV) -800 -1000 FT (MHz) Ta =2 5℃ Ta =1 00℃ -100 100 Transition Frequency -500 IC (mA) IC (mA) VCEsat (mV) -600 Collector Emitter Saturation Voltage VBEsat (mV) Base Emitter Saturation Voltage Ta=25℃ Collector Current Collector Current -500 -100 -1000 -800 -1 -10 Collector Current -1000 -0 -1 10 VCE= -10V Ta=25℃ 1 -3 -10 Collector Current -100 IC (mA) 3/6 MMBTSB1198 PNP Transistor Package Outline SOT-23 Dimensions in mm Ordering Information Device Package Shipping MMBTSB1198 SOT-23 3,000PCS/Reel&7inches www.pingjingsemi.com Revision:2.0 Mar-2021 4/6 MMBTSB1198 PNP Transistor Conditions of Soldering and Storage  Recommended condition of reflow soldering Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust the following parameters:  Time length of peak temperature (longer)  Time length of soldering (longer)  Thickness of solder paste (thicker)  Conditions of hand soldering  Temperature: 370 OC  Time: 3s max.  Times: one time   Storage conditions Temperature 5 to 40 OC  Humidity 30 to 80% RH  Recommended period One year after manufacturing www.pingjingsemi.com Revision:2.0 Mar-2021 5/6 MMBTSB1198 PNP Transistor Package Specifications  The method of packaging Cover Tape 3,000 pcs per reel SOT-23 Carrier Tape 30,000 pcs per box 10 reels per box 120,000 pcs per carton 4 boxes per carton  Embossed tape and reel data D A T2 T1 Symbol A B C E F D T1 T2 B C E Value (unit: mm) Ø 177.8±1 2.7±0.2 Ø 13.5±0.2 Ø 54.5±0.2 12.3±0.3 9.6+2/-0.3 1.0±0.2 1.2±0.2 F Reel (7'') www.pingjingsemi.com Revision:2.0 Mar-2021 6/6
MMBTSB1198R 价格&库存
很抱歉,暂时无法提供与“MMBTSB1198R”相匹配的价格&库存,您可以联系我们找货
MMBTSB1198R
  • 50+0.12600
  • 500+0.11340
  • 5000+0.10500
  • 10000+0.10080
  • 30000+0.09660
  • 50000+0.09408
