MMBTSC2412R
MMBTSC2412R
    PJ(平晶)
    SOT-23
    通用三极管 SOT23-3 NPN VCEO=50V VCE(sat)=0.4V Ic=0.15A PD=200mW
MMBTSC2412R 数据手册
MMBTSC2412 NPN Transistor Features  SOT-23 For Switching and AF Amplifier Applications. Equivalent Circuit 1.Base 2.Emitter 3.Collector 3.Collector Marking Code : MMBTSC2412Q:1Q MMBTSC2412R:1B MMBTSC2412S:1C 1.Base 2.. Emitter Absolute Maximum Ratings Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbol Value Unit Collector Base Voltage VCBO 60 V Collector Emitter Voltage VCEO 50 V Emitter Base Voltage VEBO 7 V Collector Current IC 150 mA Maximum Power Dissipation PD 200 mW Junction Temperature TJ 150 ℃ TSTG -55 to +150 ℃ Storage Temperature Range www.pingjingsemi.com Revision:2.0 Oct-2021 1/6 MMBTSC2412 NPN Transistor Electrical Characteristics (TA=25℃) Parameter Symbol Min. Typ. Max. Unit 120 -- 270 180 -- 390 270 -- 560 ICBO -- -- 100 nA IEBO -- -- 100 nA V(BR)CBO 60 -- -- V V(BR)CEO 50 -- -- V V(BR)EBO 7 -- -- V VCE(sat) -- -- 0.4 V VBE(sat) -- -- 1 V FT -- 180 -- MHz Cob -- -- 3.5 pF DC Current Gain at VCE = 6 V, IC = 1 mA Gain Group Q R HFE S Collector Base Cutoff Current at VCB = 60V Emitter Base Cutoff Current at VEB = 7 V Collector Base Breakdown Voltage at IC = 50 μA Collector Emitter Breakdown Voltage at IC = 1 mA Emitter Base Breakdown Voltage at IE = 50 μA Collector Emitter Saturation Voltage at IC = 50 mA, IB = 5 mA Base Emitter Saturation Voltage at IC = 50 mA, IB = 5 mA Transition Frequency at VCE = 12 V, IE = 2 mA, f = 100 MHz Output Capacitance at VCB = 12 V, f = 1 MHz www.pingjingsemi.com Revision:2.0 Oct-2021 -- 2/6 MMBTSC2412 NPN Transistor 1 0.5 0.2 0 100 50 20 10 0.2 0.5 1 2 0 0.4 0.8 5 10 20 50 100 200 I C/I B =10 0.2 o Ta=100 C o 25 C o -55 C 0.02 2 5 10 20 50 100200 Collector Current IC (mA) www.pingjingsemi.com Revision:2.0 Oct-2021 1.6 2.0 o 25 C o -55 C 100 50 20 10 0.2 0.5 1 2 5 10 20 50 100 200 0.5 I C/I B =50 o Ta=100 C o 25 C o -55 C 0.2 0.1 0.05 0.02 0.01 0.2 0.5 1 2 5 10 20 50 100 Collector Current IC (mA) 30 A Ta=25 oC 27 A 24 A 8 21 A 6 18 A 4 12 A 2 6 A 15 A 9 A 3 A 0 0 4 8 12 16 20 I B =0A Collector to Emitter Voltage VCE (V) 0.5 Ta=25 oC 0.2 I C/I B =50 20 10 0.1 0.05 0.02 0.01 0.2 0.5 1 2 5 10 20 50 100 200 Collector Current IC (mA) Collector Current IC (mA) Collector Saturation Voltage VCE(sat) (V) 0.5 1.2 I B =0A o Ta=100 C VCE=5V 200 Collector Current IC (mA) Collector Saturation Voltage VCE(sat) (V) 0.05mA Collector to Emitter Voltage VCE (V) DC Current Gain hFE DC Current Gain hFE VCE=5V 3V 1V 0.2 0.5 1 0.10mA 20 500 200 0.01 0.15mA 40 Ta=25 oC 0.05 0.25mA 0.20mA Base to Emitter voltage VBE (V) 0.1 0.30mA 60 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 500 0.35mA 80 10 Collector Saturation Voltage VCE(sat) (V) 2 -55 oC 5 25 oC 10 0.50mA 0.45mA 0.40mA Ta=25 oC Collector Current IC (mA) Collector Current IC (mA) 20 0.1 100 VCE=6V Transition Frequency fT (MHz) 50 Ta=100 oC Collector Current IC (mA) Typical Characteristic Curves Ta=25 oC VCE=6V 500 200 100 50 -0.5 -1 -2 -5 -10 -20 -50 -100 Emitter Current IE (mA) 3/6 MMBTSC2412 NPN Transistor Package Outline SOT-23 Dimensions in mm Ordering Information Device Package Shipping MMBTSC2412 SOT-23 3,000PCS/Reel&7inches www.pingjingsemi.com Revision:2.0 Oct-2021 4/6 MMBTSC2412 NPN Transistor Conditions of Soldering and Storage  Recommended condition of reflow soldering Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust the following parameters:  Time length of peak temperature (longer)  Time length of soldering (longer)  Thickness of solder paste (thicker)  Conditions of hand soldering  Temperature: 370 OC  Time: 3s max.  Times: one time   Storage conditions Temperature 5 to 40 OC  Humidity 30 to 80% RH  Recommended period One year after manufacturing www.pingjingsemi.com Revision:2.0 Oct-2021 5/6 MMBTSC2412 NPN Transistor Package Specifications  The method of packaging Cover Tape 3,000 pcs per reel SOT-23 Carrier Tape 30,000 pcs per box 10 reels per box 120,000 pcs per carton 4 boxes per carton  Embossed tape and reel data D A T2 T1 Symbol A B C E F D T1 T2 B C E Value (unit: mm) Ø 177.8±1 2.7±0.2 Ø 13.5±0.2 Ø 54.5±0.2 12.3±0.3 9.6+2/-0.3 1.0±0.2 1.2±0.2 F Reel (7'') www.pingjingsemi.com Revision:2.0 Oct-2021 6/6
MMBTSC2412R 价格&库存
很抱歉,暂时无法提供与“MMBTSC2412R”相匹配的价格&库存,您可以联系我们找货
MMBTSC2412R
  • 50+0.05100
  • 500+0.04590
  • 5000+0.04250
  • 10000+0.04080
  • 30000+0.03910
  • 50000+0.03808
