BC817-40
BC817-40
    PJ(平晶)
    SOT-23
    通用三极管 SOT23-3 NPN VCEO=45V VCE(sat)=0.7V Ic=0.5A PD=300mW
BC817-40 数据手册
BC817~BC818 NPN Transistor SOT-23 Features  For Switching and AF Amplifier Applications. Equivalent Circuit 1.Base 2.Emitter 3.Collector 3.Collector Marking Code: BC817-16 : 6CQ BC818-16 : 6CW BC817-25 : 6CS BC818-25 : 6CX BC817-40 : 6CT BC818-40 : 6CY 1.Base 2.. Emitter Absolute Maximum Ratings Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Collector Base Voltage Symbol BC817 BC818 Collector Emitter Voltage BC817 BC818 Emitter Base Voltage VCBO VCEO Value 50 30 45 25 Unit V V VEBO 5 V Collector Current IC 500 mA Maximum Power Dissipation PD 300 mW Junction Temperature TJ 150 ℃ TSTG -55 to +150 ℃ Storage Temperature Range www.pingjingsemi.com Revision:2.0 Mar-2021 1/6 BC817~BC818 NPN Transistor Electrical Characteristics (TA=25℃) Parameter Symbol Min. Tpy. Max. Unit 100 -- 250 160 -- 400 250 -- 600 40 -- -- ICBO -- -- 100 nA IEBO -- -- 100 nA VCE(sat) -- -- 0.7 V VBE(on) -- -- 1.2 V FT 100 -- -- MHz Cob -- 5 -- pF DC Current Gain at VCE = 1 V, IC = 100 mA Gain Group -16 -25 HFE -40 at VCE = 1 V, IC = 500 mA Collector Base Cutoff Current at VCB = 20V Emitter Base Cutoff Current at VEB = 5 V Collector Emitter Saturation Voltage at IC = 500 mA, IB = 50 mA Base Emitter On Voltage at VCE = 1 V, IC = 500 mA Transition Frequency at VCE = 5 V, IC = 10 mA, f = 50 MHz Output Capacitance at VCB = 10 V, f = 1 MHz www.pingjingsemi.com Revision:2.0 Mar-2021 -- 2/6 BC817~BC818 NPN Transistor DC Current Gain hFE Collector Current IC (mA) Typical Characteristic Curves Base-Emitter Voltage VBE (V) Power Dissipation PD (mW) Collector Emitter Saturation Voltage VCE(sat) (V) Collector Current IC (mA) Collector Current IC (mA) www.pingjingsemi.com Revision:2.0 Mar-2021 Ambient Temperature Ta (℃) 3/6 BC817~BC818 NPN Transistor Package Outline SOT-23 Dimensions in mm Ordering Information Device Package Shipping BC817~BC818 SOT-23 3,000PCS/Reel&7inches www.pingjingsemi.com Revision:2.0 Mar-2021 4/6 BC817~BC818 NPN Transistor Conditions of Soldering and Storage  Recommended condition of reflow soldering Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust the following parameters:  Time length of peak temperature (longer)  Time length of soldering (longer)  Thickness of solder paste (thicker)  Conditions of hand soldering  Temperature: 370 OC  Time: 3s max.  Times: one time   Storage conditions Temperature 5 to 40 OC  Humidity 30 to 80% RH  Recommended period One year after manufacturing www.pingjingsemi.com Revision:2.0 Mar-2021 5/6 BC817~BC818 NPN Transistor Package Specifications  The method of packaging Cover Tape 3,000 pcs per reel SOT-23 Carrier Tape 30,000 pcs per box 10 reels per box 120,000 pcs per carton 4 boxes per carton  Embossed tape and reel data D A T2 T1 Symbol A B C E F D T1 T2 B C E Value (unit: mm) Ø 177.8±1 2.7±0.2 Ø 13.5±0.2 Ø 54.5±0.2 12.3±0.3 9.6+2/-0.3 1.0±0.2 1.2±0.2 F Reel (7'') www.pingjingsemi.com Revision:2.0 Mar-2021 6/6
BC817-40 价格&库存
很抱歉,暂时无法提供与“BC817-40”相匹配的价格&库存,您可以联系我们找货
BC817-40
  • 50+0.06450
  • 500+0.05805
  • 5000+0.05375
  • 10000+0.05160
  • 30000+0.04945
  • 50000+0.04816
