RB521CS-30DB
RB521CS-30DB
    PJ(平晶)
    DFN1006-2L
    肖特基二极管 DFN2_1X0.6MM_EP VF=0.4V Vrrm=30V Io=0.2A Ir=30μA
RB521CS-30DB 数据手册
RB521CS-30DB Schottky Barrier Rectifiers DFN1x0.6-2L Features  Small surface mounting type C  High reliability  Low reverse current and low forward voltage &DWKRGH $QRGH Marking Code :C Absolute Maximum Ratings (TA=25℃) Parameter Symbols Value Unit DC Reverse Voltage VR 30 V Mean Rectifying Current IO 200 mA Non-repetitive Peak Forward Surge Current at t=8.3ms IFSM 0.5 A Power dissipation PD 200 mW RθJA 500 °C/W TJ 125 °C TSTG -40 to +125 °C Symbols Max. Unit VF 0.35 V Thermal Resistance Junction to Ambient Operating Junction Temperature Storage Temperature Range Electrical Characteristics (TA=25℃) Parameter Forward Voltage at IF = 10mA at IF = 20mA Reverse Current at VR = 10 V www.pingjingsemi.com Revision:1.0 Dec-2021 0.40 IR 30 µA 1/3 RB521CS-30DB Schottky Barrier Rectifiers Typical Characteristic Curves 1000 1000 100 o Ta=100 C Reverse Current IR (μA) =1 00 o C 10 o C a T 1 T= a 2 5 Forward Current IF (mA) 100 10 o Ta=25 C 1 0.1 0.01 0 100 200 300 400 500 0.1 600 0 5 10 Forward Voltage VF (V) 15 20 25 30 Reverse Voltage VR (V) 100 220 Ta=25℃ 200 30 Power Dissipation PD (mW) Capacitance Between Terminals CT (pF) f=1MHz 10 160 120 80 3 40 1 0 5 10 Reverse Voltage VR (V) www.pingjingsemi.com Revision:1.0 Dec-2021 15 20 0 0 25 50 75 100 125 Ambient Temperature TA (℃) 2/3 RB521CS-30DB Schottky Barrier Rectifiers Package Outline DFN1x0.6-2L-0011 Dimensions in mm 0.6±0.05 0.5±0.05 0.5±0.03 0.25±0.03 1±0.05 0.65 BSC 0.25±0.03 0~0.03 TOP VIEW SIDE VIEW BOTTOM VIEW Ordering Information Device Package Shipping RB521CS-30DB DFN1x0.6-2L 10,000PCS/Reel&7inches www.pingjingsemi.com Revision:1.0 Dec-2021 3/3
RB521CS-30DB 价格&库存
很抱歉,暂时无法提供与“RB521CS-30DB”相匹配的价格&库存,您可以联系我们找货
RB521CS-30DB
  • 50+0.07050
  • 500+0.06345
  • 5000+0.05875
  • 10000+0.05640
  • 30000+0.05405
  • 50000+0.05264
库存:8249
RB521CS-30DB
  • 20+0.10284
  • 200+0.08010
  • 600+0.06746
  • 2000+0.05988
  • 10000+0.05074
  • 20000+0.04718
库存:5944
