C1E-96.000-8-1216-X2-M 数据手册
Customer Name :
Customer P/N
Frequency
: 96.000000
MHz
Aker Approved P/N: C1E-96.000-8-1216-X2-R
Aker MPN
Rev.
:1
ISSUE DATE
: Mar.9.2021
APPROVED
CHECKED
Xtal
PREPARED
Kiku
APPROVED BY CUSTOMER
AKER TECHNOLOGY CO., LTD.
ADDRESS : NO 11-3, Jianguo Rd., T.E.P.Z ,Tanzi Dist., Taichung City 427, Taiwan.
TEL:886-4-25335978
Web: www.aker.com.tw
FAX : 886-4-25336011
MSL:Level 1
RoHS compliant
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
SHEET : 1 of 9
Xtal
REV . : 1
Kiku
Rev.
Date
Reviser
Revise contents
1
2021/3/9
Kiku
Initial Released
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
Xtal
SHEET : 2 of 9
Kiku
REV . : 1
SMD CRYSTAL SPECIFICATION
1 . ELECTRICAL CHARACTERISTICS
Standard atmospheric conditions
Unless otherwise specified , the standard range of atmospheric conditions for making measurement
and tests are as follow :
Ambient temperature : 25±5℃
Relative humidity
: 40%~70%
If there is any doubt about the results , measurement shall be made within the following limits :
Ambient temperature : 25±3℃
Relative humidity
: 40%~70%
AKER Model : CXAN-211
Oscillation Model : Fundamental
Cutting Model : AT CUT
Measurement Equipment : 350A(Measured FL)
Insulation Resistance : More than 500M ohms at DC 100V
Electrical Spec
Parameters
Nominal Frequency
Symbol
Min.
Typ.
Max.
96.000000
FL
Notes
Units.
MHz
Frequency Tolerance
±12
ppm at 25℃ ± 3℃
Frequency Stability
±16
ppm
8
pF
Load Capacitance
CL
Operating Temperature
-40
105
Storage Temperature Range
-55
125
0.01
400
uW
Drive Level
DL
Equivalent Series Resistance
ESR
Ω
C0
2
pF
Shunt Capacitance
Spurious Mode Series Resistance
1100
Ω
Operating Temp (Refer 25℃)
including Aging
@Series
F0±700k Hz
*Please kindly be noted that AKER DO NOT guarantee parts quality which involves human security application.*
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
Xtal
SHEET : 3 of 9
Kiku
REV . : 1
2 . MARKING :
96
AAc
FREQUENCY
Year/Month Code:Please make refer to following tables.
Production line code
AKER LOGO.
3 . DIMENSION :
( Unit : mm )
< S ID E >
2 .0 ± 0 .1 5
1.6 ± 0.15
#4
C e r a m ic B a s e
#3
M e ta l L id
AKER
#1
#2
0 .5 M a x .
1 .2 8
0 .7
#2
#4
#3
0.78
0.48
0.5
0.98
#1
0 .8 8
0 .5 8
# 2 :G N D
# 4 :G N D
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
Xtal
SHEET : 4 of 9
Kiku
REV . : 1
4 . STRUCTURE ILLUSTRATION
A
C
B
D
G
N
I
K
R
A
M
E
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
Xtal
SHEET : 5 of 9
Kiku
REV . : 1
5 . PACKING :
TAPE SPECIFICATION
A
A
B
4.0 ± 0.10
1.10 ± 0.05
5° (max)
B-B SECTION
3.50 ± 0.05
B
0.25 ± 0.02
2.30 ± 0.10
4.0 ± 0.10
8.0 ± 0.20
1.55 ± 0.05
1.75 ± 0.10
2.0 ± 0.05
( Unit : mm )
0.65 ± 0.10
1.90 ± 0.10
5° (max)
Feeding
A-A SECTION
OUTLINE DIMENSION
( Unit : mm )
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
6. COVER TAPE ADHESION STRENGTH:
7 . SOLDERING REFLOW PROFILE
Xtal
SHEET : 6 of 9
Kiku
REV . : 1
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
Xtal
SHEET : 7 of 9
Kiku
REV . : 1
8. PACKING :
185mm
183mm
36mm
BOX = 3000 PCS / REEL(MAX)
Stuff
210mm
625mm
390mm
SMD product packs 32 BOX=The outside box packs (3000 PCS *32 BOX = 96000 PCS)(MAX)
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
Xtal
SHEET : 8 of 9
Kiku
REV . : 1
9 . MECHANICAL PERFORMANCE
TEST ITEMS
TEST METHODS AND TEST CONDITION
9.1 Drop Test
The specimen is measured for its frequency and
resistance before the test. It is then dropped from
a hight of 100 cm or more as a free fall object onto
a hard wooden plate of 30mm or more in thickness.
( in accordance with JIS-C0044 )
9.2 Vibration Test
and resistance before the test. Most them into
X,Y and Z axes, respectively, for the vibration test.
Vibration condition:
Frequency range ; 20~2000HZ
Peak to peak amplitude : 1.52 mm
Peak acceleration : 20G
Sweep time : 20 minute / axis
Pendicular total test time : 4 hours
( in accordance with MIL-STD-883F : 2007.3 )
resistance before the test. Place the specimen on
the belt of the converynace and let it pass through
the reflow with the presetted temperature condition.
After passing twice the reflow place,the specimen
under the referee condition for -~2 hours and then
measure its electrical performance.
Temperature Condition of IR Simulation:
The temperature range of the preheated section
is setted at 150~180℃ for 60~120 sec. For the next
section the temperature range is setted at 217~260℃
for 45~90 sec. and within this time range the specimen
should be able to sustain at the peak temperature,
260+/-3℃ , for 10 sec long.
( in accordance with JESD22-B106-B )
Place the specimen in a pressurized container and
pressurize it with the detection gas ( mixed gas
consisting of 95% or more helium ) for at least 2 hours.
Complete the measurement of the concentration of
helium within 30 min after taking it out from the
pressurized container.
9.3 Resistance to
Soldering Test
9.4 Fine Leak
Test
( in accordance with MIL-STD-883F : 1014.11 )
The referee condition .
Temperature 25 ± 2 ℃
Humidity
44 ~ 55 %
Pressure
86 ~ 106 kPa
( in accordance with MIL-STD-883E : 1014. 9 )
PERFORMANCE
To satisfy the electrical
performance .
Less than
1.0 * 10 - 8 atm .c.c. / sec,
Helium
CUST. P/N
Aker Approved P/N
APPROVED
PREPARED
Xtal
SHEET : 9 of 9
Kiku
REV . : 1
10 . CLIMATIC RESISTANCE
TEST ITEMS
10.1 Low Temp
Exposure Test
resistance before the test .
Place the specimen in the chamber and kept it
at the temperature of - 40 ± 3℃ for 168 ± 6 hours .
Take the specimen out of the chamber
and measure itselectrical performance after
leaving 1~2 hours under the referee condition.
( in accordance with JIS-C0020 )
10.2 Aging Test
Place the specimen in the testing chamber and keep it
at the temperature of + 125 ± 3℃ for 720 ± 48 hours.
And then take the specimen out of the chamber and
measure its electrical performance after leaving
for 1 ~ 2 hours under the referee condition .
( in accordance with JIS-C0021 )
10.3 High
Temperature &
High Humidty
and resistance before the test .
kept it at the temperature of + 85 ± 5 ℃ and
humidity of 85 ± 5 % for 168 ± 6 hours.and
then take the specimen out and measure its
electrical performance after leaving for 1~2
( in accordance with MIL-STD-883F : 1004.7 )
10.4 Temperature
Cycle Test
Subject the specimen to the 100 cycles of
temperature ranges stated below .
High temp . + 125 ± 3 ℃ (15± 3 min).
2~3 min.
2~3 min.
Low temp . -55 ±3 ℃ (15± 3 min).
Measure its electrical performance after leaving it
( in accordance with MIL-STD-883F : 1010.8 )
PERFORMANCE
performance .
C1E-96.000-8-1216-X2-M 价格&库存
很抱歉,暂时无法提供与“C1E-96.000-8-1216-X2-M”相匹配的价格&库存,您可以联系我们找货
