RA10M00000L100
RA10M00000L100
    NEXTGEN
    DIP-14
    有源晶振 10MHz 5V DIP-14
RA10M00000L100 数据手册
PART CODE: RA10M00000L100 SPECIFICATION SHEET SPECIFICATION SHEET NO. N0504-RA10M00000L100 DATE May 04, 2021 REVISION A0 DESCRIPITION MHz Thru-Hole Crystal Oscillator, L20.8*W13.2*H5.08mm Full- Size/14 pin, CO14 series 10.00000MHz, 5.0V, +/-50ppm, Symmetry 45/55, Operating Temp. Range -40°C ~+85°C, HCMOS//50pF, Supply Current 10mA Max, Tristate function - Enable Thru-Hole type, Packed in Tube, 25pcs/Tube RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER TGS CO1451BGI05 BLF−10M000 PART CODE RA10M00000L100 VENDOR APPROVE Issued/Checked/Approved DATE: May 04, 2021 CUSTOMER APPROVE DATE: NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: RA10M00000L100 MHZ THRU-HOLE CRYSTAL SMD CRYSTAL OSCILLATOR 2520 CO14 TYPE 4SERIES PADS MAIN FEATURE • MHz Thru-Hole Crystal Oscillator L20.8*W13.2*H5.08mm • Industry-standard • Hermetically sealed package for reliability • Tristate function -Disable • Cross more competitors part • RoHS/RoHS III compliant APPLICATION • Communication Electronics RFQ PART CODE GUIDE Request For Quotation RA 10M00000 L 001 1 2 3 4 1) RA: Part family Code for MHz Thru-Hole Crystal Oscillator, L20.8*W13.2*H5.08mm, Full-Size/14 pin, CO14 series 2) 10M00000: Frequency range code for 10.0000MHz 3) L: Thru Hole type, Packed in Tube, 25pcs/Tube 4) 100: Specification code for original part No.: TGS CO1451BGI05 BLF-10M000 MORE FREQUENCY RANGE AVAILABLE (MHz) 2.0480 20.000 24.000 NextGen Components, Inc. 25.000 27.000 40.0000 sales@NextGenComponent.com 48.000 50.000 100.00 125.000 www.NextGenComponent.com PART CODE: RA10M00000L100 MHZ THRU-HOLE CRYSTAL OSCILLATOR CO14 SERIES DIMENSION (Unit: mm, Tol. +/-0.15mm) Image for reference Marking Line 1: 10.0000 Line 2: Special Code CO14 Pin Function #1 Tristate Enable Via #1 #4 Ground #5 Output #8 VDD Circuit Principle NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com RA10M00000L100 PART CODE: MHZ THRU-HOLE CRYSTAL OSCILLATOR CO14 SERIES ELECTRICAL PARAMETERS Parameter Part No. Symbol Units Value Min. Original Manufacturer Holder Type Typical Condition Max. TGS TGS Crystals CO14 MHz Thru-Hole Crystal Oscillator, CO14 Series, L20.8*W13.2*H5.08mm, Full-Size/14 pin Supply Voltage 5 Enable/Disable -Tristate Function 1 Overall Freq. Tolerance B ppm -50 +50 Operating Temp. Range G °C -40 +85 °C -55 +125 % 45 55 V OH V 90% V OL V Load pF Storage Temp. Range Symmetry Output I Output Waveform V 5.0 +/-10% Tristate function - Enable @ Control via pin 1 High (Logic “1”) 10% HCMOS @OutputLoad 50pF Startup Time ms 10 Supply Current mA 10 Rise/ Fall time ns 10 Phase Jitter ps Others Low (Logic “0”) 50 05 Aging @25°C N/A ppm/year @1st year ±3 Package L Thru - Hole type, Packed in Tube, 25pcs/Tube RoHS Status LF RoHS III compliant Add Value N/A Internal Control Code * N/A Frequency Range -10M0000 10.0000MHz Note: 1) Original Part Number: TGS CO1451BGI05 BLF-10M000 2) * Internal Control Code- 2 letter or digits; Blank: N/A NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: RA10M00000L100 MHZ THRU-HOLE CRYSTAL OSCILLATOR CO14 SERIES ENVIRONMENTAL AND TECHNICAL CONDITIONS Test Items Test Method And Conditions Temperature Cycle Mil-std 883, Method 1010, 10 Cycles -20° C To 85° C Shock Mil-std-202, Method 213, Test Condition C Vibration Mil-std-202, Method 204, Test Condition A Resistance To Soldering Heat Mil-std-202, Method 210, Test Condition B Humidity 85% Relative Humidity At 85° C 250 Hours Gross Leak Test Mil-std-883, Method 1014, Test Condition C Fine Leak Test Mil-std-883, Method 1014, Test Condition A Terminal Strength Mil-std-202, Method 211, Test Condition A And C Moisture Resistance Moisture Resistance Mil-std 202, Method 106, Omit Step 7b Solderability Mil-std-202, Method 208, 95% Coverage Solvent Resistance Mil-std-202, Method 2002, Method 215 DISCLAIMER NextGen Components, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com
RA10M00000L100 价格&库存
很抱歉,暂时无法提供与“RA10M00000L100”相匹配的价格&库存,您可以联系我们找货
