QTT216
Temperature Compensated Crystal Oscillator
Fuel The Digital World
Features
Applications
Frequency range : 10MHz to 70MHz
SMD seam sealing ceramic package
Supply voltage : 1.8V & 3.3V
Clipped Sinewave output
Low power consumption
Voltage control function available
External dimensions (mm)
L : 2.0 x W : 1.6 x H : 0.8
RoHS compliant & Pb free
Mobile communications
GNSS
Smartphone, Mobile phone
Wearables
IoT devices
Portable radio communications
Electrical Characteristics
Item
Nominal Frequency Range (F0)
Frequency Tolerance (Ftol)
vs Temperature
Frequency Stability vs Load
vs Supply Voltage
Operating Temperature Range (T OTR)
QTT216
Conditions
10MHz ~ 70MHz
±2.0 ppm Max.
Note [1]
±0.5ppm, ±2.0ppm
Note [2]
±0.2 ppm Max.
Load ±10%
±0.2 ppm Max.
VDD ±5%
-30°C ~ +85°C
Supply Voltage (VDD)
1.8V, 3.3V
Current Consumption (IDD)
2.0 mA Max.
Output Type
Clipped Sinewave
Output Load
10kΩ // 10pF
Output Level
0.8 V(p-p) Min.
Start-up Time
5 ms Max.
Note [3]
Auto Frequency Control (AFC) Range
±7ppm ~ ±16ppm
VCTCXO, optional, Note [4]
Phase Noise
-135 dBc/Hz Typ.
at 1kHz offset
Aging (Faging)
±1 ppm Max.
Storage Temperature Range (TSTR)
at 25°C, first year
-55°C ~ +125°C
Notes:
[1] Refer to nominal frequency after 2 times of reflow at 25°C.
[2] Refer to frequency at 25°C±2°C.
[3] Decoupling capacitor is required in external circuit.
[4] If supply voltage VDD = 3.3V, control voltage Vcon = 0.5*VDD ± 1.0V.
If supply voltage VDD = 1.8V, control voltage Vcon = 0.5*VDD ± 0.8V.
Rev. 1.04
Page 1
www.qstproducts.com
QTT216
Dimensions
Pin function
Function
Pin
TCXO
1
VCTCXO
GND or NC
AFC
2
GND
3
OUTPUT
4
VDD
Recommended pad layout
(Unit: mm)
Ordering Information
QTT216
26.000M B G
Frequency in Hz
T
Packaging Method
T
Please contact us for
available frequencies
Tape & Reel
Supply Voltage
B
D
3.3 V
1.8 V
Frequency Stability (over Temp.)
N
S
G
V
Rev. 1.04
± 2.0 ppm
± 2.0 ppm
± 0.5 ppm
± 0.5 ppm
Page 2
( -30°C ~ +85°C ),
( -30°C ~ +85°C ),
( -30°C ~ +85°C ),
( -30°C ~ +85°C ),
TCXO
VCTCXO
TCXO
VCTCXO
www.qstproducts.com
QTT216
Packing
(Unit: mm)
(Unit: mm)
Reflow Profile
Solder melting point : 220°C, 60 sec. Min., 200 sec. Max.
Peak temperature : 260°C, 10 sec. Min., 30 sec. Max.
(°C)
10 sec
260
220
180
150
120 sec
Rev. 1.04
60 sec
Page 3
Time (sec)
www.qstproducts.com
很抱歉,暂时无法提供与“QTT216-38.400MBG-T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+11.532241000+1.48030
