CPPHV7
CPPHV7
    CARDINALCOMPONENTS
    SMD-6
    可编程晶振 3.3V SMD-6
CPPHV7 数据手册
CARDINAL COMPONENTS Programmable LVDS Oscillator Series Applications * LVDS Output * Factory Programmable * Differential LVDS Output * Industry Standard Packaging CPPHV * Serial Communications * Routers * Switches * WAN Interfaces * Test Equipment Part Numbering Example: CPPHV7-A7BR-Freq. Max Unit 200 700 MHz -25 + 25 ppm 3.465 V Specifications: Min Frequency Range: Stability: Supply Voltage: 3.125 Typ 3.3 Operating Temperature: -40 + 85 °C Storage Temperature: -55 + 125 °C Duty Cycle: 45 55 % 10 mS 5 ppm 130 mA Start-Up Time: 3 Aging: (ppm/1st Year) Ta=25C, Vdd=3.3V Static Discharge Voltage: 2000 V Supply Current: Short Circuit Current: Jitter (RMS) Period: Output Voltage Voh Vol ± 50 mA 10 pS 1.6 V V 1.0 nS 0.9 Rise/Fall Time: 0.7 Output Level: LVDS Packaging: Tape and Reel 1000 pcs per Reel Tristate internal pull up, output active when high Dimensions are in mm LVDS Levels Test Circuit OUT 50 ? Vo PIN 1 2 3 4 5 6 50 ? ___ OUT Function OE (CMOS) Do Not Connect Ground LVDS + LVDS Vdd Solder Pad Layout Cardinal Components, Inc. 155 Route 46 West Wayne, NJ 07470 Rev: C-090414-11 O-22 TEL: (973)785-1333 E-MAIL: sales@cardinalxtal.com WEB: http://www.cardinalxtal.com
CPPHV7 价格&库存
很抱歉,暂时无法提供与“CPPHV7”相匹配的价格&库存,您可以联系我们找货
