CPPHE7
CPPHE7
    CARDINALCOMPONENTS
    SMD-6
    可编程晶振 3.3V SMD-6
CPPHE7 数据手册
CARDINAL COMPONENTS Programmable LVPECL Oscillator Series CPPHE Applications * LVPECL Output * Factory Programmable * Differential LVPECL Output * Industry Standard Packaging * Serial Communications * Routers * Switches * WAN Interfaces * Test Equipment Part Numbering Example: CPPHE7-A7BR-Freq. Specifications: Min Frequency Range: 200 Stability: Typ -25 Supply Voltage: 3.125 3.3 Max Unit 700 MHz + 25 ppm 3.465 V Operating Temperature: -40 + 85 °C Storage Temperature: -55 + 125 °C Duty Cycle: 45 Start-Up Time: 3 Aging: (ppm/1st Year) Ta=25C, Vdd=3.3V Static Discharge Voltage: % 10 mS 5 ppm 130 mA 2000 V Supply Current: Short Circuit Current: Jitter (RMS) Period: Output Voltage Voh Vol 55 ± 50 mA 10 pS Vdd - 1.025 Rise/Fall Time: 0.6 Output Level: Vdd - 1.62 V V 1.5 nS LVPECL Packaging: Tape and Reel 1000 pcs per Reel Tristate internal pull up, output active when high LVPECL Levels Test Circuit Dimensions are in mm Vdd OUT 50 ? 2.0 V PIN 1 2 3 4 5 6 50 ? ___ OUT Function OE (CMOS) Do Not Connect Ground LVPECL + LVPECL Vdd Solder Pad Layout Cardinal Components, Inc. 155 Route 46 West Wayne, NJ 07470 Rev: C-090414-11 O-30 TEL: (973)785-1333 E-MAIL: sales@cardinalxtal.com WEB: http://www.cardinalxtal.com
CPPHE7 价格&库存
很抱歉,暂时无法提供与“CPPHE7”相匹配的价格&库存,您可以联系我们找货
