LFXTAL014948BULK
LFXTAL014948BULK
    IQD
    HC49S
    无源晶振 27.12MHz ±30ppm 10pF 40Ω -10℃~+60℃
LFXTAL014948BULK 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL014948Bulk Customer Part: Description Industry standard leaded package Resistance welded, hermetically sealed in an inert atmosphere, glass to metal seals on leads Model HC49/4H Model Issue number 15 Frequency Parameters Frequency 27.120MHz Frequency Tolerance Tolerance Condition Frequency Stability ±30.00ppm @ 25°C ±50.00ppm Operating Temperature Range -10.00 to 60.00°C Overtone Order Ageing 3RD ±5ppm typical per year at 25°C Outline (mm) Electrical Parameters Load Capacitance (CL) Shunt Capacitance (C0) Series Resonant 7pF max Drive Level ESR 500µW max 100.00Ω max Environmental Parameters Storage Temperature Range: -55 to 125°C Shock: 981m/s², 6ms, 3 times in each of 3 mutually perpendicular planes Vibration: 10Hz-60Hz, 0.75mm amplitude, 60Hz-500Hz, 98.1m/s², 30mins in 3 mutually perpendicular planes Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Typical Frequency vs Temperature Curves Packaging Details Pack Style: Bulk Pack Size: 100 Loose in Bulk pack Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 16 Dec 21 2:05 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL014948BULK
物料型号为LFXTAL014948,封装形式为Bulk。
器件简介为工业标准有铅封装,通过惰性气氛下的电阻焊接和玻璃对金属的密封来实现密封。
引脚分配遵循HC49/4H标准,型号为15。
频率参数包括27.120MHz的频率,频率公差为±30.00ppm @ 25°C,±50.00ppm在-10.00到60.00°C的温度范围内,3RD频率稳定性为±5ppm,典型年变化为±5ppm,频率温度曲线典型值在25°C时为±25ppm。
电气参数包括最大7pF的并联电容(C0)、最大500μW的驱动电平、最大100.00的等效串联电阻(ESR)。
环境参数包括-55到125°C的存储温度范围,981m/s²的冲击,以及在不同频率下的振动测试。
封装信息显示,封装风格为散装,包装尺寸为100个/包,另有其他包装选项可供选择。
符合RoHS和REACH标准。
销售联系方式包括英国、德国、法国、美国的电话和电子邮件地址,以及公司网站。
LFXTAL014948BULK 价格&库存
很抱歉,暂时无法提供与“LFXTAL014948BULK”相匹配的价格&库存,您可以联系我们找货
