PJM03N60SQ
N-Channel Enhancement Mode Power MOSFET
SOT-89
Features
⚫ Trench FET Power MOSFET
⚫ VDS= 60V,ID= 3A
RDS(on)< 105mΩ @VGS= 10V
1. Gate
2.Drain
3.Source
Marking Code: W10
Applications
Schematic Diagram
⚫ DC/DC Converter
2.Drain
⚫ Battery Switch
1.Gate
3.Source
Absolute Maximum Ratings
Ratings at 25℃ ambient temperature unless otherwise specified.
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
60
V
Gate-Source Voltage
VGS
±20
V
Drain Current-Continuous
ID
3
A
Drain Current-Pulsed Note1
IDM
10
A
Maximum Power Dissipation
PD
1.5
W
Junction Temperature
TJ
150
°C
TSTG
-55 to +150
°C
RθJA
83
°C/W
Storage Temperature Range
Thermal Characteristics
Thermal Resistance,Junction-to-Ambient Note2
www.pingjingsemi.com
Revision:3.0 Feb-2022
1/7
PJM03N60SQ
Electrical Characteristics
(Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test Condition
Min.
Typ.
Max.
Unit
Drain-Source Breakdown Voltage
V(BR)DSS
VGS=0V,ID=250μA
60
V
Zero Gate Voltage Drain Current
IDSS
VDS=60V,VGS=0V
1
μA
Gate-Body Leakage Current
IGSS
VGS=±20V,VDS=0V
±100
nA
Gate Threshold Voltage Note3
VGS(th)
VDS=VGS,ID=250μA
1.0
2.5
V
Drain-Source On-Resistance Note3
RDS(on)
VGS=10V,ID=3A
70
105
mΩ
VGS=4.5V,ID=3A
82
125
mΩ
VDS=5V,ID=3A
1.4
2.5
S
250
pF
26
pF
Static Characteristics
Forward Transconductance Note3
gFS
Dynamic Characteristics
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
pF
Turn-on Delay Time
td(on)
6.5
nS
Turn-on Rise Time
tr
VDD=30V,ID=1.5A
15.2
nS
Turn-off Delay Time
td(off)
VGS=10V,RGEN=1Ω
15.2
nS
VDS=30V,VGS=0V,f=1MHz
Switching Characteristics
Turn-off Fall Time
tf
10.3
nS
Total Gate Charge
Qg
7
nC
Gate-Source Charge
Qgs
1.2
nC
Gate-Drain Charge
Qgd
1.5
nC
0.8
1.2
V
3
A
VDS=30V,ID=3A, VGS=4.5V
Source-Drain Diode Characteristics
Diode Forward Voltage Note3
VSD
Diode Forward Current Note2
IS
VGS=0V,IS=3A
Note: 1. Repetitive Rating: Pulse width limited by maximum junction temperature.
2. Surface Mounted on FR4 Board, t ≤ 10 sec.
3. Pulse Test: Pulse width≤300μs, duty cycle≤0.5%.
2/7
PJM03N60SQ
Typical Characteristic Curves
3/7
PJM03N60SQ
Package Outline
SOT-89
Dimensions in mm
Ordering Information
Device
Package
PJM03N60SQ
SOT-89
Shipping
1,000PCS/Reel&7inches
3,000PCS/Reel&13inches
4/7
PJM03N60SQ
Conditions of Soldering and Storage
Recommended condition of reflow soldering
Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust
the following parameters:
Time length of peak temperature (longer)
Time length of soldering (longer)
Thickness of solder paste (thicker)
Conditions of hand soldering
Temperature: 370 OC
Time: 3s max.
Times: one time
Storage conditions
Temperature
5 to 40 OC
Humidity
30 to 80% RH
Recommended period
One year after manufacturing
5/7
PJM03N60SQ
Package Specifications
The method of packaging (1,000PCS/Reel&7inches)
Cover Tape
1,000 pcs per reel
SOT-89
Carrier Tape
8,000 pcs per box
8 reels per box
32,000 pcs per carton
4 boxes per carton
Embossed tape and reel data
D
A
T1
E
B
G
F
Reel (7'')
symbol
Value(unit:mm)
A
Φ179±1
B
60.5±0.2
C
15.3±0.3
D
12.5~13.7
E
Φ13.5±0.2
F
Φ10.0±0.2
G
2.7±0.2
T1
1.0±0.2
C
6/7
PJM03N60SQ
The method of packaging (3,000PCS/Reel&13inches)
3,000 pcs per reel
SOT-89
9,000 pcs per box
3 reels per box
36,000 pcs per carton
4 boxes per carton
B
A
T
symbol
E
D
F
Reel (13'')
A
B
C
D
E
F
T
Value(unit:mm)
φ330±1
12.7±0.5
16.5±0.3
φ99.5±0.5
φ13.6±0.3
2.8±0.3
1.9±0.2
C
7/7
很抱歉,暂时无法提供与“PJM03N60SQ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.60686
- 100+0.50890
- 300+0.45987
- 国内价格
- 5+0.32131
- 20+0.29296
- 100+0.26461
- 500+0.23625
- 1000+0.22302
- 2000+0.21357
