PJ54 Series
Low Dropout Regulators
Description
SOT-23
3.VIN
The PJ54 Series is a high input voltage,low quiescent current,lowdropout linear regulator able to provide 300mA load current The LDO
features very fast response against line voltage transient and load
current transient, and ensures no overshoot voltage during the LDO
1.GND
start up and short circuit recovery.
2.VOUT
SOT-23-3
The device features integrated short-circuit and thermal shutdown
3.VIN
protection.
Features
⚫ Low Quiescent Current:2.1uA
1.GND
⚫ High Input Voltage Rating:Up to 55V
⚫ Maximum Output Current: 350mA
2.VOUT
SOT-89
⚫ Low Dropout : 350mV @ 100mA
2.VIN
⚫ High PSRR:85dB at 1KHz
⚫ Fixed Output Voltages:1.8V,2.8V,3V,3.3V,5V
⚫ Fast Transient Response
⚫ Current Limiting Protection
⚫ Thermal Shutdown Protection
1.GND 2.VIN 3.VOUT
⚫ Available Packages:SOT-23、SOT-23-3、SOT-89
SOT-23-5
SOT-23-5 and DFN1x1-4L Packages
4. NC
5. VOUT
Applications
⚫ Battery-Powered Equipment
⚫ Smoke Detector and Sensor
⚫ Micro Controller Applications
1.VIN
2.GND
3.EN
DFN1x1-4L
Bottom View
3.EN
2.GND
GND
1.VOUT
www.pingjingsemi.com
Revision:5.0 Dec-2021
4.VIN
1 / 12
PJ54 Series
Functional Pin Description
Pin Name
Pin Function
EN
Chip Enable (Active High). Note that this pin is high impedance
NC
NO Connected
GND
Ground
VOUT
Output Voltage
VIN
Power Input Voltage
Ordering Information
PJ54
Package Type
SA:SOT-23
SC:SOT-23-3
SQ:SOT-89
SE:SOT-23-5
DE:DFN1x1-4L
Output Voltage
18 : 1.8V 28 : 2.8V 30 : 3.0V
33 : 3.3V 50 : 5.0V
Output current tap
M : 350mA
Marking Code Note
Output Voltage
Package
Marking Code
1.8V~5V
SOT-23
54XX
1.8V~5V
SOT-23-3
54XXC
1.8V~5V
SOT-23-5
54XXE
1.8V~5V
SOT-89
54XX
1.8V~5V
DFN1x1-4L
54XX
Note . XX : Output Voltage
e.g . 30:3.0V 33:3.3V
Typical Application Circuit
PJ54 Series
2 / 12
PJ54 Series
Function Block Diagram
Absolute Maximum Ratings
Ratings at 25℃ ambient temperature unless otherwise specified.
Parameter
Value
Unit
VIN to GND Voltage
-0.3 ~ +55
V
VOUT to GND Voltage
-0.3 ~ +6
V
VOUT to VIN Voltage
-55 ~ +0.3
V
EN to GND Voltage
-0.3 ~ +55
V
Internally limited
SOT-23
300
mW
SOT-23-3
400
mW
SOT-89
600
mW
SOT-23-5
400
mW
DFN1x1-4L
400
mW
SOT-23
380
°C/W
SOT-23-3
300
°C/W
SOT-89
180
°C/W
SOT-23-5
300
°C/W
DFN1x1-4L
300
°C/W
-40 ~ +85
°C
150
°C
-40 ~ +150
°C
Output Current
Power Dissipation
Thermal Resistance,Junction-to-Ambient
Operating Ambient Temperature
Junction temperature
Storage temperature range
3 / 12
PJ54 Series
Electrical Characteristics
(VIN=VOUT+1, CIN=1µF, COUT=10µF, TA=25℃ , unless otherwise noted.)
Parameter
Input Voltage
Symbol
Test Conditions
VIN
Output Voltage Accuracy
Quiescent Current
Typ.
Max.
Unit
3
45
V
∆VOUT
VIN=12V, IOUT=10mA
-2
+2
IQ
VIN=12V, IOUT=0mA
2.1
μA
300
350
mA
VIN=VOUTNOM-0.1V, IOUT=10mA
35
VIN=VOUTNOM-0.1V, IOUT=100mA
350
0.01
%/V
0.02
%/mA
ILIM
500
mA
IOUT_Max
Dropout Voltage
VDROP
Line Regulation
∆VLINE
Load Regulation
∆VLOAD
Current Limit
Min.
VOUTNOM+0.5V≤VIN≤40V
IOUT=1mA
VIN=12V,
1mA
很抱歉,暂时无法提供与“PJ54M33SQ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.53720
- 20+0.48980
- 100+0.44240
- 500+0.39500
- 1000+0.37288
- 2000+0.35708
- 国内价格
- 5+0.89079
- 50+0.70416
- 150+0.61085
