LFXTAL009650RL3K
LFXTAL009650RL3K
    IQD
    SMD3225_4P
    无源晶振 16MHz ±10ppm 16pF 70Ω -40℃~+85℃
LFXTAL009650RL3K 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL009650RL3K Customer Part: Description Standard 3.2 x 2.5mm SMD crystal in a ceramic package with a seam sealed metal lid, hermetically sealed. Model CFPX-180 Model Issue number 10 Frequency Parameters Frequency 16.0MHz Frequency Tolerance Tolerance Condition Frequency Stability ±10.00ppm @ 25°C ±20.00ppm Operating Temperature Range -40.00 to 85.00°C Overtone Order Ageing Fundamental ±5ppm max per year @ 25°C Electrical Parameters Outline (mm) 16.00pF 7pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 100µW max 70.00Ω max Environmental Parameters Storage Temperature Range: -55 to 125°C Shock: MIL-STD-202F, Method 213B: 1000G, 0.5ms, 1/2 sine wave Vibration: MIL-STD-202F, Method 204D, Test Condition D: 20G (10Hz-2000Hz), 4hrs in 3 mutually perpendicular planes (total 12hrs) Manufacturing Details RoHS Terminations RoHS Reflow Temp NiAu 260degC 10s Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: RL3K Pack Size: 3,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 3 Dec 21 14:19 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL009650RL3K
1. 物料型号:型号为“LM78M05ABDT-ND”,LM78M05ABDT是德州仪器(Texas Instruments)生产的一个正电压输出的线性稳压器。
2. 器件简介:LM78M05ABDT是一个正5V输出的线性稳压器,具有低静态电流和高输出电流能力,适用于需要稳定电源的场合。
3. 引脚分配:该器件的引脚从左到右依次为输入引脚、接地引脚和输出引脚。
4. 参数特性:包括输入电压范围、输出电压、输出电流、静态电流等。
5. 功能详解:LM78M05ABDT能够提供稳定的5V输出电压,适用于多种电子设备。
6. 应用信息:适用于需要稳定电源的场合,如微处理器供电、传感器供电等。
LFXTAL009650RL3K 价格&库存
很抱歉,暂时无法提供与“LFXTAL009650RL3K”相匹配的价格&库存,您可以联系我们找货
