7M-27.120MBGE-T
7M-27.120MBGE-T
    TXC(台晶)
    SMD-4
    无源晶振 12pF ±50ppm 60Ω -40℃~+85℃ 27.12MHz SMD-4
7M-27.120MBGE-T 数据手册
7M MHz Crystal Features Applications Frequency range : 10MHz to 114MHz Ceramic SMD package Seam sealing External dimensions (mm) L : 3.2 x W : 2.5 x H : 0.7 RoHS compliant & Pb free Bluetooth, Wireless LAN Cellular phone, Pager, DSC Display, TV Computer peripherals Consumer products Electrical Characteristics Item 7M Conditions Frequency Range F0 10MHz ~ 114MHz Frequency Tolerance Ftol ±30ppm, ±20ppm, ±10ppm Frequency Stability over Operating Temperature Range (refer to 25°C) Operating Temperature Range Fstab TOTR ±30 ppm ±20 ppm ±10 ppm ±10 ppm ±30 ppm ±20 ppm ±15 ppm ±60 ppm -20°C ~ +70°C -40°C ~ +85°C -40°C ~ +125°C Shunt Capacitance C0 Drive Level DL 1 ~ 200μW (100μW Typ.) Load Capacitance CL 6pF, 8pF, 9pF, 10pF 12pF, 16pF, 18pF, 20pF Aging (at 25°C ± 3°C, first year) Faging ±3ppm Max. Storage Temperature Range TSTR -55°C ~ +125°C at 25°C -20°C ~ +70°C -30°C ~ +85°C -40°C ~ +85°C -40°C ~ +125°C 3pF Max. Note [1] Notes: [1] Please contact us for low aging +/-1ppm grade crystals. Motional Resistance (ESR) Fundamental 10 ~ 12 12 ~ 16 16 ~ 20 20 ~ 64 Rev. 1.08 MHz MHz MHz MHz 150Ω 80Ω 60Ω 50Ω 3rd Overtone Max. Max. Max. Max. 60 ~ 80 MHz 80 ~ 114 MHz Page 1 80Ω Max. 60Ω Max. www.txccrystal.com 7M MHz Crystal Dimensions Ordering Information 7M - 20.000M A H E Frequency in Hz - T Packaging Method T Please contact us for available frequencies Tape & Reel Load Capacitance Frequency Tolerance (at 25°C) A D E ± 30 ppm ± 20 ppm ± 10 ppm Frequency Stability (over Temp.) A D E T H I J K Rev. 1.08 ± 30 ppm ± 20 ppm ± 10 ppm ± 10 ppm ± 30 ppm ± 20 ppm ± 15 ppm ± 60 ppm B V C Q E I J K 6 pF 8 pF 9 pF 10 pF 12 pF 16 pF 18 pF 20 pF ( -20°C ~ +70°C ) ( -20°C ~ +70°C ) ( -20°C ~ +70°C ) ( -30°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +125°C ) Page 2 www.txccrystal.com 7M MHz Crystal Packing (Unit: mm) (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 10°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.08 60 sec Page 3 Time (sec) www.txccrystal.com
7M-27.120MBGE-T
物料型号:7M MHz Crystal
器件简介:该晶体振荡器采用陶瓷SMD封装,具有密封接缝,频率范围从10MHz到114MHz,符合RoHS标准且无铅。
引脚分配:文档提供了顶视图和侧视图,显示了晶体振荡器的引脚布局,其中包含GND和晶体连接。
参数特性:包括频率范围、频率容差、频率稳定性、工作温度范围、并联电容、驱动电平、负载电容、老化率和存储温度范围。
功能详解:文档详细描述了晶体振荡器的电气特性,包括基本频率、三次谐波频率和ESR(等效串联电阻)。
应用信息:适用于计算机外设、消费产品、手机、寻呼机、DSC显示、电视、蓝牙、无线局域网等。
封装信息:提供了晶体振荡器的尺寸和建议的布局,以及包装方法和订购信息。
7M-27.120MBGE-T 价格&库存
很抱歉,暂时无法提供与“7M-27.120MBGE-T”相匹配的价格&库存,您可以联系我们找货
7M-27.120MBGE-T
  • 3000+4.448443000+0.57829
