LFXTAL082087RL3K
LFXTAL082087RL3K
    IQD
    SMD2520_4P
    无源晶振 40MHz ±10ppm 10pF 70Ω -20℃~+70℃
LFXTAL082087RL3K 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL082087RL3K Customer Part: Description 2.5 x 2mm SMD crystal in a hermetically sealed ceramic package with a seam sealed metal lid. Model CFPX-218 Model Issue number 4 Frequency Parameters Frequency 40.0MHz Frequency Tolerance Tolerance Condition Frequency Stability ±10.00ppm @ 25°C ±10.00ppm Operating Temperature Range -20.00 to 70.00°C Overtone Order Ageing Fundamental ±3ppm max per year @ 25°C Electrical Parameters Outline (mm) 10.00pF 5pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 100µW max 70.00Ω max Environmental Parameters Storage Temperature Range: -55 to 125°C Drop: 100cm drop (3 times) onto hard wooden board. Vibration: MIL-STD-883F, Method 2007.3: 20G (20Hz-2000Hz), 1.52mm amplitude, 20mins in 3 mutually perpendicular planes (total 4hrs). Manufacturing Details Maximum Process Temperature: 260°C (10secs max) RoHS Terminations NiAu RoHS Reflow Temp 260°C max for 10secs max Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: RL3K Pack Size: 3,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 7 Dec 21 1:35 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL082087RL3K
- 物料型号:LFXTAL082087RL3K - 器件简介:2.5 x 2mm SMD晶体,采用密封陶瓷封装,带有密封金属盖。 - 引脚分配:1. Crystal Pad Connections, 2. GND, 3. Crystal, 4. GND - 参数特性: - 频率:40.0MHz - 频率容差:±10.00ppm - 频率稳定性:±10.00ppm(在25°C时) - 基频 - 老化:±3ppm每年(在25°C时) - 负载电容(CL):10.00pF - 并联电容(C0):最大5pF - 驱动级别:最大100µW - 等效串联电阻(ESR):最大70.00Ω - 功能详解:文档未提供详细功能描述。 - 应用信息:文档未提供具体应用信息。 - 封装信息:2.5 x 2mm SMD晶体,密封陶瓷封装,带有密封金属盖。 - 环境参数:存储温度范围:-55至125°C,跌落测试:100cm跌落至硬木板(3次),振动测试:MIL-STD-883F, 方法2007.3:20G(20Hz-2000Hz),1.52mm振幅,20分钟在3个相互垂直的平面上(总计4小时)。 - 制造细节:最大工艺温度:260°C(最多10秒),RoHS端接:NiAu 260°C最多10秒,RoHS回流温度。 - 合规性:符合RoHS(2015/863/EU)和REACh标准。 - 湿度敏感等级(MSL):不适用。 - 包装细节:RL3K包装风格,按照EIA-481-D标准胶带和卷轴包装,包装大小:3000。 - 销售办公室联系方式:提供了英国、法国、德国和美国的联系电话和电子邮件地址。
LFXTAL082087RL3K 价格&库存
很抱歉,暂时无法提供与“LFXTAL082087RL3K”相匹配的价格&库存,您可以联系我们找货
LFXTAL082087RL3K
    • 1+7.71120
    • 200+3.07800
    • 500+2.98080
    • 1000+2.92680
