NNENCLJNNF-10.000000
    TAITIEN(泰艺)
    SMD-4
    有源晶振 10MHz 3.3V SMD-4
NNENCLJNNF-10.000000 数据手册
NN Type 9.7 x 7.5 x 4.1mm "Formosa" Oven Controlled Crystal Oscillator FEATURE - Taitien's patented “Formosa” ASIC technology - Dimension 9.7 x 7.5mm, miniaturized 4-Pad SMD package - Low Power Consumption - ±20 ppb stability over -40 to 85°C - Stratum 3 (Overall ±4.6 ppm including 20 years aging.) TYPICAL APPLICATION - Small Cell, Portable Telecommunication Device - Test and Instrumentation - Synthesizer , Digital switch , Reference Timing Circuit - Packet Timing Protocol (e.g. IEEE-1588) RoHS Compliant Formosa Inside DIMENSION 0.236 6.00 0.382 MAX 9.7 0.236 6.00 PIN CONNECTIONS PIN 0.295 MAX 7.5 0.157 4.0 0.16 4.1 (See NOTE 1) Numbers for reference only. (Not stamped on unit) (VIEW FROM BOTTOM) or NOT CONNECTED 2 0 VOLTS AND CASE 3 R.F. OUTPUT 4 +VDC 0.059 DIA.(4 PLACES) 1.5 SEE NOTE 2&3 0.059 DIA.(4 PLACES) 1.5 [VIEW FROM TOP] FUNCTION VCO INPUT 1 0.157 4.0 RECOMMENDED SOLDER PAD LAYOUT Notes 1. If the specification does not specify parameters for PIN 1 , then PIN 1 must remain unconnected. Notes 2. Copper in this area should be kept to a minimum to reduce heat loss from OCXO. Notes 3. Bottom side refiow is forbidden unless specified in oscillator specification. Notes 4. Aqueous cleaning is FORBIDDEN Notes 5. Test condition : A 0.1uF and 10uF X7R decoupling capacitor is required close to the unit. ELECTRICAL SPECIFICATION Parameter Min. Output Frequency Typ. 10 Max. Unit 40 MHz Rectangular Clipped Sine Wave Form Available frequency range from 10MHz 40MHz. TestisCondition &to Notes Standard frequencies are 10, 12.8, 19.2, 20, 25, and 30.72MHz. Please contact us for detail information Level 2.4 “1” Level “0” Level Duty Cycle Rectangular Clipped Sine Load (Rectangular/Clipped Sine) Spurious V 0.4 55 50 45 0.8 % @+1.65 V Vp-p 15pF / 10Kohm//10pF -60 dBc -20 +20 ppb -40°C to +85°C, referenced to (Fmax + Fmin)/2 Refer to Table:Freq. Stability vs Temp. Range. -3.0 -0.6 -3.0 +3.0 +0.6 +3.0 ppb after 30 days continues operation -5 -0.1 +5 +0.1 Frequency Stability Ambient Aging Daily Yearly 10 years Voltage Warm-up Phase Noise @ 20 MHz ppm ppb ppm ±5% Change In 5 minutes @ +25°C, referenced to 1 hour @ 10 Hz -98 -92 -126 -120 -145 -152 -140 -150 dBc/Hz @ 100 Hz @ 1 kHz @ 10 kHz Electrical Frequency Adjustment -5.0 Range 5.0 0 Control 1.65 Slope VCO@ 0V VCO@ 3.3V V Positive Input impedance Input Power 3.3 ppm Kohm 100 Voltage 3.3 3.135 Current Steady state 0.3 5.0V input voltage is available. Please contact us for detail information. 3.465 V 350 mA @ turn on 0.4 W @ +25°C FREQ. STABILITY vs. TEMP. RANGE Temp. (°C) * ppb ±5 -20 ~ +70 △ -40 ~ +85 X ±10 ±20 ±30 ±50 △ ○: Available △:Conditional X: Not available Note: not all combination of options are available. Other specifications may be available upon request. Specifications subject to change without notice. www.taitien.com sales@taitien.com.tw Rev(4) 07/2020 107
物料型号:文档中没有明确给出型号,但提到了“Formosa” ASIC技术。
器件简介: - 采用台系专利的“Formosa” ASIC技术。 - 尺寸为9.7 x 7.5mm,4-Pad小型SMD封装。 - 低功耗设计。 - 在-40至85°C范围内稳定性为±20ppb。 - Stratum 3级别,包括20年老化在内整体精度±4.6ppm。
引脚分配: - 引脚1:未连接。 - 引脚2:电压和外壳。 - 引脚3:输出。
参数特性: - 输出频率波形:10MHz至40MHz,标准频率有10, 12.8, 19.2, 20, 25, 30.72MHz等。 - 负载能力:15pF/10Kohm//10pF。 - 频率稳定性:环境温度变化在-40°C至+85°C,老化日稳定性为±3.0ppb,年稳定性为±0.6ppm(10年)。 - 相位噪声:在不同频率下有不同的dBc/Hz值。
功能详解: - 适用于小型基站、便携式通信设备、测试和仪器、合成器、数字交换机、参考时钟电路、包时序协议(如IEEE-1588)等。
应用信息: - 符合RoHS标准。
封装信息: - 提供了详细的尺寸和引脚布局图。
电气规格表详细列出了各种参数,包括输出频率、波形、电平、占空比、负载能力、频率稳定性、相位噪声、电气频率调整范围、控制方式、输入阻抗、输入功率、电压、电流等。
NNENCLJNNF-10.000000 价格&库存
很抱歉,暂时无法提供与“NNENCLJNNF-10.000000”相匹配的价格&库存,您可以联系我们找货
  • 1+382.261731+45.70582
  • 10+362.5078310+43.34391
  • 50+355.9152350+42.55565
  • 100+342.73230100+40.97941
库存:79
