LFXTAL082132Reel
LFXTAL082132Reel
    IQD
    SMD-4
    无源晶振 40MHz 8pF ±10ppm 60Ω -40℃~+85℃ SMD-4
LFXTAL082132Reel 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL082132Reel Customer Part: Description 2 x 1.6mm SMD crystal Ceramic package with a seam sealed metal lid, hermetically sealed Model IQXC-42 Model Issue number 1 Frequency Parameters Frequency 40.0MHz Frequency Tolerance Frequency Stability ±10.00ppm ±15.00ppm Operating Temperature Range -40.00 to 85.00°C Overtone Order Ageing Fundamental ±3ppm max per year @ 25°C Electrical Parameters Outline (mm) 8.00pF 3pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 100µW max 60.00Ω max Environmental Parameters Shock: IEC 60068-2-27: 1000G, 1ms, 3 times in each of 3 mutually perpendicular planes Vibration: IEC 60068-2-6: 1.5mm amplitude, 10Hz-55Hz, 1min in 3 mutually perpendicular planes, duration 2hrs each plane (total 6hrs) Storage Temperature Range: –55 to 125°C Manufacturing Details RoHS Terminations RoHS Reflow Temp NiAu 260degC 10s Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 1,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 6 Sep 21 1:22 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL082132Reel
1. 物料型号:LFXTAL082132Reel 2. 器件简介:2 x 1.6mm SMD晶体,采用陶瓷封装,带有密封金属盖,密封性良好。 3. 引脚分配:文档中未明确列出引脚分配,但通常SMD晶体会有GND和晶体两个引脚。 4. 参数特性: - 频率:40.0MHz - 频率容差:±10.00ppm - 频率稳定性:在-40.00至85.00°C的工作温度范围内 - 谐波阶数:Fundamental(基频) - 老化:±3ppm每年,25°C条件下 5. 功能详解:文档中未提供详细的功能解释,但晶体通常用于为电子设备提供稳定的时钟信号。 6. 应用信息:适用于需要高精度时钟信号的应用。 7. 封装信息:封装尺寸为55mm x 38mm,采用EIA-481-D标准的胶带和卷轴包装。
LFXTAL082132Reel 价格&库存
很抱歉,暂时无法提供与“LFXTAL082132Reel”相匹配的价格&库存,您可以联系我们找货
