501-33920
501-33920
    WENZEL(文策尔)
    DIP-5
    有源晶振 10MHz 12V DIP-5
501-33920 数据手册
OUTPUT Frequency 10 MHz Level +10 dBm ±3 dB into 50 ohms STABILITY Aging -10 ±5 x 10 per day after 30 days operating, typical REV DATE - 04-28-21 REVISION RECORD DWN AUTH BH LR Draft OTHER Label Label as follows: 501-33920 10 MHz VDC SN – Date Code -8 ±5 x 10 per year after 180 days operating, typical Phase Noise L(f) 10 Hz -126 dBc/Hz 100 Hz -146 dBc/Hz 1 kHz -160 dBc/Hz 10 kHz -165 dBc/Hz 100 kHz -165 dBc/Hz Temperature Stability -8 ±2 x 10 , 0°C to +50°C (Ref +25°C) -8 ±5 x 10 , -20°C to +70°C (Ref +25°C) -7 ±1 x 10 , -40°C to +85°C (Ref +25°C) MECHANICAL Dimensions ≤ 1.03” x 1.03” x 0.515” Connectors Solder pins on base Packaging Solder sealed steel can POWER REQUIREMENTS Warm-Up Power
501-33920 价格&库存
很抱歉,暂时无法提供与“501-33920”相匹配的价格&库存,您可以联系我们找货
