501-33926
501-33926
    WENZEL(文策尔)
    SMA
    有源晶振 100MHz 12V~15V SMA
501-33926 数据手册
OUTPUT Frequency 100 MHz Level +13 dBm ± 2 dB into 50 ohms, -20 to +70°C +13 ± 3 dB into 50 ohms, -55 to +85°C STABILITY Aging (typical) -6 per year after 30 days operating -7 second year 1 x 10 5 x 10 -7 3 x 10 per year, thereafter Phase Noise L(f) 100 Hz -126 dBc/Hz 1 kHz -146 dBc/Hz 10 kHz -165 dBc/Hz 100 kHz -165 dBc/Hz Temperature Stability REV DATE - 04-28-21 REVISION RECORD Initial Release DWN AUTH BH LR ADJUSTMENT Mechanical Tuning -6 ±4 x 10 Electrical Tuning -7 ±5 x 10 , ±5 VDC, Negative slope CRYSTAL Type 100 MHz SC-cut OTHER Label Label as follows: 501-33926 10 MHz +12/+15VDC SN - Date Code -7 ±2 x 10 , 0° to +50°C (Ref +25°C) -7 ±5 x 10 , -20 to +70°C (Ref +25°C) -6 ±2 x 10 , -55° to +85°C (Ref +25°C) Harmonics ≤ -30 dBc Spurious ≤ -80 dBc MECHANICAL Packaging Solder sealed steel can Dimensions 2 x 2 x 0.75” Connectors / Mounting SMA(f) and solder pins on side; threaded inserts, #4-40, 2 places POWER REQUIREMENTS Warm-Up Power ≤ 6 Watts for 5 minutes at +25°C Total Power ≤ 3 Watts at +25°C Supply Voltage +12 VDC ±5% and +15 VDC ±5% Wenzel Associates, Inc. Austin, Texas Title: 100 MHz-SC Sprinter Crystal Oscillator P/N: 501-33926 Tolerances: (except as noted) Dimensions are in inches Rev: Date: 0.XX Dec: 0.030” Drawn: Ref: 27514 04-28-21 0.XXX Dec: 0.010” FSCM: 62821 Page 1 of 1
501-33926 价格&库存
很抱歉,暂时无法提供与“501-33926”相匹配的价格&库存,您可以联系我们找货
