SXO75C3C171-16.000M
SXO75C3C171-16.000M
    SUNTSU
    SMD7050_4P
    有源晶振 16.000000MHz ±25ppm 3.3V -10℃~+70℃ CMOS
SXO75C3C171-16.000M 数据手册
Ceramic SMT 4 Pad CMOS Oscillator SXO75C Series 7.0mm x 5.0mm Features Applications • ±20ppm (Frequency Stability) Available • Micro Processors • Ceramic Package • SONET/SDH/DWDM • CMOS • Storage Area/Networking • Tape and Reel • Digital Video • Base Stations • Part Numbering Guide SXO 75 C 3 A 48 1 X - 25.000M SUNTSU OSC 7.0mm x 5.0mm CMOS SUPPLY VOLTAGE 1 : 1.8V±5% 2 : 2.5V±5% 3 : 3.3V±5% 5 : 5.0V±5% CO M P L I A N T FREQUENCY STABILITY A : ±50ppm B : ±30ppm C : ±25ppm *D : ±20ppm Cage Code : 4GUT4 To customize your parameters, contact a Suntsu representative. * For Frequency stability option D, contact a Suntsu representative. ** For operating temperatures up to -55-125°C contact a Suntsu representative. Electrical Parameters Units Minimum Frequency Range KHz 32.768* Frequency Range MHz 1 200* (*125MHz Max for 5.0V Option) ppm -20 +20 See part numbering guide for options See part numbering guide for options Frequency Stability (Includes Initial Tolerance at 25°C, Frequency Stability over Operating Temperature, Output Load Change, Supply Voltage Change, and First Year Aging at 25°C.) Operating Temperature Typical FREQUENCY MHz LOAD BLANK : 15pF TRI-STATE X : 30pF (ENABLE/DISABLE) OPERATING BLANK : No Connection Y : 50pF TEMPERATURE RANGE 1: Pin 1 07 : 0°C - +70°C 16 : -10°C - +60°C 17 : -10°C - +70°C 27 : -20°C - +70°C 38 : -30°C - +85°C 48 : -40°C - +85°C Maximum °C -40 +85 Storage Temperature °C -55 +125 Supply Voltage (VDD) - 1.8V option V 1.710 1.8 1.890 Supply Voltage (VDD) - 2.5V option V 2.375 2.5 2.625 Supply Voltage (VDD) - 3.3V option V 3.135 3.3 3.465 Supply Voltage (VDD) - 5.0V option V 4.75 5.0 5.25 1.8V 2.5V 3.3V / 5.0V Frequency Range Current (IDD) 32.768KHz mA 5 5 5 / *NA Maximum Value (*32.768KHz not available in 5.0V) 1.0000MHz - 34.999MHz mA 8 10 16 / 25 Maximum Value 35.000MHz - 59.999MHz mA 10 20 25 / 40 Maximum Value 60.000MHz - 99.000MHz mA 25 30 40 / 70 Maximum Value 100.000MHz - 200.000MHz mA 35 50 65 / 90* Output Load (CMOS) pF 15 V Output Logic Levels Low (VOL) V 0.1*VDD 32.768KHz ns 200 1.0000MHz - 34.999MHz ns 10 35.000MHz - 99.999MHz ns 6 100.000MHz - 200.000MHz ns Symmetry (Duty Cycle) 0.9*VDD 3 % 45 Tri-State Input Voltage - Enable V 0.7*VDD Tri-State Input Voltage - Disable V 0.3*VDD Start-Up Time ms 10 Phase Jitter (12kHz ~ 20MHz) ps 1 www.suntsu.com Specifications are subject to change without notice. Maximum Value (*at 125MHz Max for 5.0V) See part numbering guide for options Output Logic Levels High (VOH) Rise (TR) and Fall (TF) Time Remarks (*32.768KHz not available in 5.0V) 50 55 No Connection Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 4 Pad CMOS Oscillator SXO75C Series 7.0mm x 5.0mm Outline Drawing & Land Pattern All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. Test Circuit (CMOS) Waveform (CMOS) Typical Phase Noise Performance (Measured By Agilent E5052A) Frequency - 25.000MHz www.suntsu.com Specifications are subject to change without notice. Frequency - 100.000MHz Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 4 Pad CMOS Oscillator SXO75C Series 7.0mm x 5.0mm Typical Jitter Performance (Measured By Agilent E5052A) Frequency - 25.000MHz Frequency - 100.000MHz Reflow Profile Part Marking Tp (Time At 260°C. 20-40 Sec) 260 Rup (Ramp Up, 3°C/Sec Max) 217 Temperature (°C) 200 TI (Time Above 217°C. 60-150Sec) 150 Rdn (Ramp Down, 6°C/Sec Max) Ts (Preheat Time. 60-180Sec) T 25°C to Peak (480Sec Max) Time (sec) Tape And Reel Dimensions All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. 1,000pcs/Reel www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 4 Pad CMOS Oscillator SXO75C Series 7.0mm x 5.0mm Environmental Specifications Mechanical Specifications Temperature Cycling MIL-STD-883, Method 1010, Condition B Mechanical Shock MIL-STD-202, Method 213, Condition B Fine Leak Test MIL-STD-883, Method 1014, Condition A Vibration MIL-STD-883, Method 2007, Condition A Gross Leak Test MIL-STD-883, Method 1014, Condition C Moisture Resistance MIL-STD-883, Method 1004 Solderability MIL-STD-883, Method 2003 Resistance to Solvents MIL-STD-202, Method 215 Moisture Sensitivity J-STD-020, MSL 1 Resistance to Soldering Heat MIL-STD-202, Method 210, Condition K www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301
SXO75C3C171-16.000M
物料型号:SXO75C系列
器件简介:该系列是一款陶瓷表面贴装4引脚CMOS振荡器,具有±20ppm的频率稳定性,适用于多种应用领域。
引脚分配: - 引脚1:三态或无连接 - 引脚2:地(GND) - 引脚3:输出 - 引脚4:电源电压(VDD)
参数特性: - 频率范围:32.768KHz至200MHz - 频率稳定性:根据选项不同,可达到±20ppm至±50ppm - 工作温度范围:根据选项不同,从-40°C至+85°C - 存储温度范围:-55°C至+125°C - 供电电压:1.8V、2.5V、3.3V、5.0V选项 - 工作电流:根据频率范围和供电电压,从5mA至90mA不等 - 输出负载:15pF - 输出逻辑电平:高(VoH)为0.9VDD,低(VoL)为0.1Vpp
功能详解: - 三态功能允许振荡器输出在不需要时可以禁用 - 提供了频率稳定性选项,可以根据需要选择不同的稳定性等级 - 支持多种工作温度范围,以适应不同的环境需求
应用信息: - 微处理器 - SONET/SDH/DWDM - 存储区域/网络 - 数字视频基站
封装信息:7.0mm x 5.0mm的CMOS封装,符合Cage Code 4GUT4标准。
环境和机械规格: - 符合MIL-STD-883和J-STD-020标准,包括温度循环、泄漏测试、振动、湿度抵抗等 - 焊接性和耐溶剂性也符合相应标准
测试电路和波形:提供了测试电路图和CMOS波形示例,包括输出高电平(VoH)、输出低电平(VoL)和对称性(占空比)。
典型相位噪声性能:在25MHz和100MHz频率下,提供了相位噪声性能图表。
典型抖动性能:提供了25MHz和100MHz频率下的抖动性能图表。
回流焊接曲线:提供了推荐的回流焊接温度曲线。
标记和封装尺寸:提供了产品标记规范和胶带及卷轴尺寸信息。
联系方式:Suntsu Electronics, Inc. 提供了联系信息,包括电话、传真和网站。
SXO75C3C171-16.000M 价格&库存
很抱歉,暂时无法提供与“SXO75C3C171-16.000M”相匹配的价格&库存,您可以联系我们找货
