501-33925-XX
501-33925-XX
    WENZEL(文策尔)
    DIP-5
    有源晶振 12V 100MHz DIP-5
501-33925-XX 数据手册
OUTPUT Frequency 100 MHz Level +10 ±2 dBm min. into 50 ohms STABILITY Aging -6 ±1 x 10 per year after 30 days operating, typical Phase Noise L(f), typical, Static 100 MHz 10 Hz -90 dBc/Hz *typical 100 Hz -126 dBc/Hz 1 kHz -146 dBc/Hz 10 kHz -166 dBc/Hz 100 kHz -170 dBc/Hz \ Temperature Stability ≤ ±2 x 10-7, 0° to +50°C (Ref +25°C) ≤ ±5 x 10-7, -20° to +70°C (Ref +25°C) ≤ ±1.5 x 10-6, -40° to +85°C (Ref +25°C) Harmonics ≤ -30 dBc Spurious ≤ -80 dBc MECHANICAL Dimensions ≤ 1.03” x 1.03” x 0.515” Connectors Solder pins on base, glass stand-offs Packaging Solder sealed steel can POWER REQUIREMENTS Warm-Up Power < 3W for 2.5 min Total Power 1.1W at +25°C steady state, typical Supply Voltage +12 VDC, ±1 VDC ADJUSTMENT Electrical Tuning -6 ±7 x 10 , 0 - 10 VDC Positive slope CRYSTAL Type SC-cut -01 3e-10/g per axis, guaranteed -02 2e-10/g per axis, guaranteed ENVIRONMENTAL Temperature-Altitude 40,000 feet at -40°C, operating REV DATE - 04-28-21 REVISION RECORD Initial Release DWN AUTH BH LR Storage -54° to +85°C Vibration 10 to 1000 Hz, 0.06 g2 /Hz 1000 Hz to 2000 Hz, -6dB/Octave 10 gs RMS Shock 12 gs for 11 msec, three axes Secure when mounting using MIL-Grade epoxy Humidity 95 to 100 percent relative humidity, +28° to +85°C OTHER Label Label as follows: 501-33925-XX 10MHz VDC SN – Date Code Wenzel Associates, Inc. Austin, Texas Title: 100 MHz-SC Rugged ONYX IV Crystal Oscillator P/N: 501-33925-XX Tolerances: (except as noted) Dimensions are in inches Rev: Date: 0.XX Dec: 0.030” Drawn: Ref: 24762 04-28-21 0.XXX Dec: 0.010” FSCM: 62821 Page 1 of 1
501-33925-XX 价格&库存
很抱歉,暂时无法提供与“501-33925-XX”相匹配的价格&库存,您可以联系我们找货
