S33310T-19.200-X1-R
S33310T-19.200-X1-R
    AKER(安碁科技)
    SMD3225_4P
    有源晶振 19.200000MHz 3.3V -40℃~+125℃ HCMOS
S33310T-19.200-X1-R 数据手册
RoHS Compliant Pb - Lead Free AEC-Q200 Qualified Ltr Date Revisions Appr Electrical Specifications: Frequency Range Temperature Stability Aging per Year Operating Temperature Range Storage Temperature Range Supply Voltage Automotive Temperature Input Current Output Voltage Output Symmetry Output Level Output Load Rise and Fall Time Phase Jitter (12 KHz to 20 MHz) Enable-Disable Function Output Disable Time Output Enable Time Start Up Time 2.000 to 9.999 MHz 10.000 to 19.999 Mhz 20.000 to 31.999 Mhz 32.000 to 54.000 Mhz Logic High (Voh) Logic Low (Vol) Standard Tight 2.000 to 9.999 MHz 10.000 to 19.999 Mhz 20.000 to 31.999 Mhz 32.000 to 54.000 Mhz 1.000 to 54.000 ±100 ±50 ±3 -40 to +125 -55 to +125 1.8 ± 5% 2.5 ± 5% 3.3 5 6 6 8 6 8 15 20 90% (80% at 1.8) 10% (20% at 1.8) 40 to 60 45 to 55 CMOS 15 7 5 7 5 6 5 6 5 1 Tri-State 150 300 5 10 5 (10 at 1.8 Vdd) MHz PPM Max ºC ± 10% 7 7 12 20 Vdd mA Max Vdd Min Vdd Max % pF Max 5 5 5 5 ns Max ps Max RMS ns Max ms Max ms Max Temperature stability is Inclusive of all conditions: Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage, supply voltage change, output load changes, shock, vilbration, and 1st year aging at +25°C. Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: Feb 7, 2017 Clock Oscillator Automotive Temperature Range Miniature - Low Profile 3.2 x 2.5 millimeter Surface Mount General Product Specification Part Number: S3 X1 Series www.aker-usa.com Mechanical Outline: Pin1 Pin 3 INH Output High or Open Operating Low High Impedance Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Page: 2/4 Date: Feb 7, 2017 P/N: www.aker-usa.com S3 X1 Series 1.5 2.0 1.75 Carrier Tape Dimensions: 4.0 B-B SECTION AKER AKER AKER AKER AKER AKER AKER AKER A 3.4 Pin #1 A 8.0 3.5 B B 1.0 4.0 1.4 2.7 A-A SECTION Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date: Feb 7, 2017 P/N: www.aker-usa.com S3 X1 Series How to build a Part Number: Series Package S 3 Parameter 2.5 x 3.2 mm Supply Voltage 33 25 18 +3.3 Vdd ± 10% +2.5 Vdd ± 5% +1.8 Vdd ± 5% Temperature Stability 10 05 ±100 PPM ±50 PPM See Notes T 40 / 60 % 45 / 55 % Duty Cycle Frequency 1.000 to 54.000 X1 Temperature Range M Packaging R R3 MHz -40 to +125 ºC 250pcs Reel 1000pcs Reel 3000pcs Reel Part Number Example: S33310-30.000-X1-R S3: 2.5 x 3.2 mm SMD Package 33: +3.3 ± 10% Vdd Supply Voltage 10: ±100 PPM Temperature Stability 30.000 MHz Nominal Frequency X1: -40 to + 125° C Automotive Temperature Range R: Tape and Reel Packaging Notes: 1- Standard Duty Cycle does not need to be included in Part Number description. 2- Product is shipped in Tape and Reel configuration. 3- Quantities less than 250pcs are shipped in tape 4- Specification subject to change without notice. Page: 4/4 Date: Feb 7, 2017 P/N: www.aker-usa.com S3 X1 Series
S33310T-19.200-X1-R 价格&库存
很抱歉,暂时无法提供与“S33310T-19.200-X1-R”相匹配的价格&库存,您可以联系我们找货
