CX635A-A5B2C3-40-18.432D13 数据手册
CARDINAL COMPONENTS
Ceramic Surface Mount Crystals
Series CX635A
CX635B
• Very low drive level
• Wide frequency range
• Tight stabilities and tolerances
Part Numbering Example: CX635A Z - A1 B2 C2 50 - 11.0 D18 - 3
CX635A
Z
A1*
B2
C2
50
11.0
D18
-3
SERIES ADDED FEATURES OPERATING TEMP. STABILITY TOLERANCE RESISTANCE FREQUENCY LOAD CAP.
OVERTONE
CX635A BLANK = BULK PACK A0 = -10°C ~ +60°C B1 = ±100 C1 = ±100 SEE CHART
D16,18,20,ETC. BLANK: FUND.
-3: 3rd OT
BELOW
CX635B Z = TAPE AND REEL A1 = -10°C ~ +70°C B2 = ± 50 C2 = ± 50
DS = SERIES
A2 = -40°C ~ +85°C B3 = ± 30 C3 = ± 30
A3 = -55°C ~ +125°C B4 = ± 10 C4 = ± 10
*NOTE: The above ABC combinations cover basic specification options. We tailor our crystal specifications
to meet customer requirements. Please contact our sales department if you don’t see exactly what you need.
Specifications:
CX635A
Frequency Range:
8.000 ~ 50.000 MHz
Operating Temperature:
-10°C ~ +70°C
-20°C ~ +70°C
-40°C ~ +85°C
Standard
YYWWCD
Frequency Stability:
±50
±30
±10
± 5
ppm
ppm
ppm
ppm
Standard
Frequency Tolerance:
(at 25°C)
±50 ppm
±30 ppm
±10 ppm
Standard
Load Capacitance:
Standard 18pF or series.
Other values are available.
Resistance:
Maximum resistance corresponds to frequency.
See chart below.
Standard:
Mode: Fundamental, 3rd or 5th Overtone
Shunt Capacitance: 7 pF Max
Aging: ± 5 ppm/year
Drive Level: 50 µW
Packaging: Tape and Reel (1K per Reel)
CX635B
Note: Not all combinations of the above tolerances, stabilities, and temperature
ranges are available. Consult the factory if your requirement is not standard.
Resistance Chart: All resistances are maximum
EQUIVALENT SERIES RESISTANCE (ESR), MODE OF OPERATION (MODE)
Frequency MHz
11.0
14.0
25.0
55.0
100.0
~ 13.99
~ 24.99
~ 54.99
~ 100.00
~ 150.00
ESR (Ω)
Oscillation Mode
50
40
30
70
100
Fundamental
Fundamental
Fundamental
3rd Overtone
5th Overtone
Cardinal Components, Inc.
1801 Broadway St
Charlottesville, VA 22902
USA
RECOMMENDED SOLDER
PAD LAYOUT
TEL:
(973)785-1333
E-MAIL: sales@cardinalxtal.com
WEB: http://www.cardinalxtal.com
CX635A-A5B2C3-40-18.432D13 价格&库存
很抱歉,暂时无法提供与“CX635A-A5B2C3-40-18.432D13”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+10.29240
- 200+4.11480
- 500+3.97440
- 1000+3.90960
