CX5Z-A2B2C5-40-25D18
    CARDINALCOMPONENTS
    SMD-4
    无源晶振 25MHz ±20ppm 18pF 40Ω -40℃~+85℃
CX5Z-A2B2C5-40-25D18 数据手册
36.000~48.0000 CARDINAL COMPONENTS Ceramic Surface Mount Series CX5 • Lowest maximum drive level available • Widest frequency range • Very tight stabilities Part Numbering Example: CX5 Z - A1 - B2 - C2 60 - 10.0 D18 - 3 CX5 Z A1* SERIES ADDED FEATURES CX5 BLANK = BULK PACK Z = TAPE AND REEL OPERATING TEMP. A0 = -10°C ~ +60°C A1 = -10°C ~ +70°C A2 = -40°C ~ +85°C A3 = -55°C ~ +125°C B2 C2 60 10.0 D18 -3 STABILITY TOLERANCE RESISTANCE FREQUENCY LOAD CAP. OVERTONE B1 = ±100 SEE CHART C1 = ±100 D16,18,20,ETC. BLANK: FUND. -3: 3rd OT B2 = ± 50 BELOW C2 = ± 50 DS = SERIES B3 = ± 30 C3 = ± 30 B4 = ± 10 C4 = ± 10 *NOTE: The above ABC combinations cover basic specification options. We tailor our crystal specifications to meet customer requirements. Please contact our sales department if you don’t see exactly what you need. Specifications: Frequency Range: CX5 7.3728MHZ~48.000MHZ Standard Operating Temperature: 0°C ~ +70°C -40°C ~ +85°C Frequency Stability: ± 50 ppm Standard Stabilities from ± 5 ppm available. Frequency Tolerance: (at 25°C) Standard ± 50 ppm Tolerances from ± 10 ppm available. Load Capacitance: Parallel or series. Please specify your required load. Resistance: Maximum resistance corresponds to frequency. See chart below. Standard: Shunt Capacitance: 7 pF Max Aging: ± 3 ppm first year Drive Level: 50 µW Max Packaging: Tape and Reel (1K per Reel) Bottom View Resistance Chart: All resistances are maximum values. EQUIVALENT SERIES RESISTANCE (ESR), MODE OF OPERATION (MODE), AND CUT Frequency MHz 7.3728~9.0000 9.0000~13.0000 13.000~16.0000 16.000~20.0000 ESR(Ω) Mode/cut 45 Max Fund./AT 40 Max Fund./AT 35 Max Fund./AT 30 Max Fund/AT Frequency MHz 20.000~30.0000 30.000~36.0000 30.000~36.0000 36.000~48.0000 Cardinal Components, Inc. 1801 Broadway St Charlottesville, VA 22902 USA ESR (Ω) Mode/cut 25 Max Fund/AT 25 Max Fund/AT 80 Max 3rd OT 80 Max 3rd OT TEL: (973)785-1333 E-MAIL: sales@cardinalxtal.com WEB: http://www.cardinalxtal.com
CX5Z-A2B2C5-40-25D18 价格&库存
很抱歉,暂时无法提供与“CX5Z-A2B2C5-40-25D18”相匹配的价格&库存,您可以联系我们找货
