CS-78.125MCB-T
CS-78.125MCB-T
    TXC(台晶)
    SMD-6
    有源晶振 2.5V 78.125MHz SMD-6
CS-78.125MCB-T 数据手册
Think of Frequency Think of SMD LVPECL SAW Oscillators - Differential Output 5.0 x 3.2 x 1.2 mm CS Series come visit our site http://www.txccorp.com Oscillators Series Features .SAW base solution. .3.3V and 2.5V operation available. 1H SY 00 S C 0 T B 212.5 .LVPECL output, output frequencies 150 MHz to 700 MHz. .Excellent low phase noise and jitter. .Tri-State function available. .Applications : Fibre Channel, Gigabit Ethernet, Serial ATA, Serial Attached SCSI, PCI-Express, SDH / SONET. .RoHS Compliant / Pb Free. Electrical Specifications CS Output Type LVPECL Output Load 50 Ω Oscillation Mode Fundamental Supply Voltage (VDD) 2.5 V , 3.3 V Frequency Range 150 ~ 700 MHz Overall Frequency Stability * ± 100 ppm , or specify Operating Temperature Range -10 ~ + 70 ℃ , - 5 ~ + 85 ℃ , or specify Storage Temperature Range - 55 ~ + 125 ℃ Voltage Vol ( Max. ) / Voh ( Min. ) VDD - 1.62 V / VDD - 1.025 V Rise ( Tr ) / Fall ( Tf ) Time ( 20 % ~ 80 % ) 1 nS Max. Supply Current 80 mA Max. Symmetry 45 ~ 55 % Start-up Time 10 mS Max. Phase Jitter ( 12 KHz ~ 20 MHz ) 1 pS Max. * Inclusive of frequency tolerance at 25 ℃, variation over temperature, supply voltage variation, aging and vibration. Dimensions 5.0±0.2 5 4 1 2 3 1.2±0.2 3.2±0.2 6 Land Pattern: 1.27 0.89 4 2 3 5 4 2.60 1.60 5 1.20 1 6 1.27 1.27 Pad dimension tolerance ±0.2 mm 70 Pin Function: 1. Enable Control or NC 2. Enable Control or NC 3. GND 4. OUT 5. OUTN 6. VDD 6 0.64 0.90 Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Item / Type 12 3 Power Supply Decoupling Capacitor is Required. Pad dimension tolerance ±0.2 mm Units: mm
CS-78.125MCB-T 价格&库存
很抱歉,暂时无法提供与“CS-78.125MCB-T”相匹配的价格&库存,您可以联系我们找货
