LFSPXO051652BULK
LFSPXO051652BULK
    IQD
    SMD5032_4P
    有源晶振 16.000000MHz 5V -40℃~+85℃ CMOS
LFSPXO051652BULK 数据手册
Crystal Clock Oscillator Specification Part No. + Packaging: LFSPXO051652Bulk Customer Part: Description 5 x 3.2 crystal oscillator Ceramic package with a seam sealed metal lid, hermetically sealed Model CFPS-12 Model Issue number 7 Frequency Parameters 16.0MHz Frequency Frequency Stability ±50.00ppm Operating Temperature Range Ageing -40.00 to 85.00°C ±3ppm max per year @ 25°C Electrical Parameters 5.0V ±0.5V Supply Voltage Current Draw 45.000mA Output Details Outline (mm) CMOS 15pF max 10.0ns max 40/60% Output Compatibility Drive Capability Rise and Fall Time Duty Cycle Output Control Enable/Disable Operation: Logic ‘1’ (>70% VS) to pad 1 enables oscillator output Logic ‘0’ (
LFSPXO051652BULK
- 物料型号:LFSPXO051652Bulk - 封装:CFPS-12 - 器件简介:5 x 3.2 mm尺寸的晶体振荡器,采用陶瓷封装和密封金属盖,密封性良好。 - 引脚分配:1.Enable/Disable, 2.GND, 3.Output, 4.+Vs - 参数特性: - 频率:16.0MHz - 频率稳定性:在-40.00至85.00°C下±50.00ppm - 老化:在25°C下每年最大±3ppm - 供电电压:5.0V ±0.5V - 电流消耗:45.000mA - 输出细节:兼容CMOS,驱动能力最大15pF,上升和下降时间最大10.0ns,占空比40/60% - 功能详解:Enable/Disable操作通过逻辑电平控制,逻辑‘1’(>70% VS)使振荡器输出启用,逻辑‘0’(<30% VS)禁用输出,禁用时振荡器输出进入高阻态。未连接时输出默认启用。待机电流最大10μA。 - 应用信息:适用于需要精确时钟信号的应用。 - 封装信息:符合RoHS标准,可再流焊温度260°C 10s,MSL等级不适用。
LFSPXO051652BULK 价格&库存
很抱歉,暂时无法提供与“LFSPXO051652BULK”相匹配的价格&库存,您可以联系我们找货
LFSPXO051652BULK
    • 1+25.39080
    • 200+10.13040
    • 500+9.79560
    • 1000+9.63360
