QT49-30.000MDDJ-B
QT49-30.000MDDJ-B
    QST(矽睿)
    HC49S
    无源晶振 30MHz ±20ppm 18pF 30Ω -20℃~+70℃
QT49-30.000MDDJ-B 数据手册
QT49 MHz Crystal Fuel The Digital World Features ● ● ● ● Applications Frequency range : 3.2MHz to 90MHz Resistance welded, metal can DIP type External dimensions (mm) L : 11.5 x W : 5.0 x H : 3.68 RoHS compliant & Pb free ● ● ● ● ● TV, STB, Cable modem Microprocessor Computer peripherals Home electronics Consumer products Electrical Characteristics Item QT49 Conditions Frequency Range F0 3.2MHz ~ 90MHz Frequency Tolerance Ftol ±30ppm, ±20ppm, ±10ppm at 25°C Frequency Stability over Operating Temperature Range Fstab ±30ppm, ±20ppm, ±10ppm refer to 25°C Operating Temperature Range TOTR -20°C ~ +70°C Shunt Capacitance C0 7pF Max. Drive Level DL 1 ~ 500μW (100μW Typ.) Load Capacitance CL 12pF, 18pF, 20pF Aging Faging ±5 ppm Max. Storage Temperature Range TSTR -55°C ~ +125°C Motional Resistance (ESR) at 25°C ± 3°C,first year Dimensions Fundamental 3.2 ~ 3.686 3.686 ~ 5 5 ~ 10 10 ~ 14 14 ~ 30 MHz MHz MHz MHz MHz 200Ω 150Ω 80Ω 40Ω 30Ω Max. Max. Max. Max. Max. Top View Side View 3rd Overtone 27 ~ 30 MHz 30 ~ 50 MHz 50 ~ 90 MHz Rev. 1.04 100Ω Max. 80Ω Max. 60Ω Max. Bottom View Page 1 (Unit: mm) www.qstproducts.com QT49 MHz Crystal Fuel The Digital World Ordering Information QT49 - 12.000M A A J - B Frequency in Hz Packaging Method B Please contact us for available frequencies Bulk Load Capacitance Frequency Tolerance (at 25°C) A D E E J K ± 30 ppm ± 20 ppm ± 10 ppm 12 pF 18 pF 20 pF Frequency Stability (over Temp.) A D E ± 30 ppm ( -20°C ~ +70°C ) ± 20 ppm ( -20°C ~ +70°C ) ± 10 ppm ( -20°C ~ +70°C ) Packing Inner box Logo sticker (carton and inner box) (Unit: mm) Rev. 1.04 Page 2 www.qstproducts.com
QT49-30.000MDDJ-B
物料型号:QT49 MHz Crystal
器件简介:QST品牌的QT49 MHz Crystal是一种用于数字世界的晶体振荡器。
引脚分配:文档中没有提供具体的引脚分配信息。
参数特性: - 频率范围:3.2MHz至90MHz - 频率容差:±30ppm, ±20ppm, ±10ppm(在25°C时) - 频率稳定性:±30ppm, ±20ppm, ±10ppm(参考25°C) - 工作温度范围:-20°C至+70°C - 并联电容:最大7pF - 驱动电平:1 ~ 500 W(典型值100 W) - 负载电容:12pF, 18pF, 20pF - 老化:首年在25°C±3°C时最大+5 ppm - 存储温度范围:-55°C至+125°C
功能详解:文档中没有提供具体的功能详解
应用信息: - 微处理器 - 电视 - 机顶盒(STB) - 有线调制解调器 - 家用电器 - 消费产品 - 计算机外围设备
封装信息:金属罐DIP类型,外部尺寸为长11.5mm x 宽5.0mm x 高3.68mm,符合RoHS且无铅。
订购信息:提供了订购型号的示例,如QT49 12.000M B,以及包装方法和负载电容的选项。
QT49-30.000MDDJ-B 价格&库存
很抱歉,暂时无法提供与“QT49-30.000MDDJ-B”相匹配的价格&库存,您可以联系我们找货
