WTL3M60688VH
WTL3M60688VH
    WTL(维拓)
    SMD3225_4P
    无源晶振 13.56MHz ±30ppm 20pF 80Ω -20℃~+70℃
WTL3M60688VH 数据手册
Quartz Crystal, Series TX3 SMD Seam Sealed Crystals 3.2×2.5×0.7 mm Feature Size 3.2×2.5, Ultra thin , thickness 0.7mm High precision and high frequency stability Excellent heat resistance and environmental characteristics Designed for automatic mounting and reflow soldering RoHS Compliant /Pb Free Electrical Specifications Item Specifications Frequency Range(MHZ) 8~10 Mode AT/Fundamental Load Capacitance (CL) 8pF, 9pF, 10pF, 12pF, 18pF, 20pF, or Specify 10~24 24~104 Frequency Tolerance( at 25°C ) ±10ppm ~ ±30ppm or specify Operating Temperature Range -20~+70℃ or Specify Frequency Stability Over Operating Temperature Range ±10ppm ~ ±30ppm or specify Equivalent Series Resistance (ESR) max. 200Ω 80Ω Storage Temperature Range -55~+125℃ Shunt Capacitance( C 0 ) 3pF Max Drive Level (Typical) 1~ 100 μW (50μW typical) Aging @25°C 1st Year (Max) ±3 ppm/year max 60Ω Dimension(mm) 3.20 ± 0.1 GND 4 3 3 2.50 ± 0.1 4 1 GND 2 1 0.70 ± 0.1 2 1.4 1.2 2 4 3 1.4 1.2 0.7 0.5 1.2 1 0.8 05 http://www.wtlcrystals.com Email:wtl@wtlcrystals.com Tel:86-755-82677582
WTL3M60688VH 价格&库存
很抱歉,暂时无法提供与“WTL3M60688VH”相匹配的价格&库存,您可以联系我们找货
