QT325G-19.200MAGJ-T
QT325G-19.200MAGJ-T
    QST(矽睿)
    SMD3225_4P
    无源晶振 19.2MHz ±30ppm 18pF 60Ω -40℃~+85℃
QT325G-19.200MAGJ-T 数据手册
QT325G MHz Crystal Fuel The Digital World Features ● ● ● ● Applications Frequency range : 9.9MHz to 54MHz Glass sealing, ceramic SMD package External dimensions (mm) L : 3.2 x W : 2.5 x H : 0.8 RoHS compliant Contains Pb, exempted by RoHS directive ● ● ● ● ● PC, TV, Game, Camera Notebook, Hard disk Computer peripherals Home electronics Consumer products Electrical Characteristics Item QT325G Frequency Range F0 9.9MHz ~ 54MHz Frequency Tolerance Ftol ±30ppm, ±20ppm, ±10ppm Frequency Stability over Operating Temperature Range (refer to 25°C) Operating Temperature Range Fstab TOTR ±30 ppm ±20 ppm ±10 ppm ±10 ppm ±50 ppm ±30 ppm ±20 ppm ±60 ppm -20°C ~ +70°C -30°C ~ +85°C -40°C ~ +85°C -40°C ~ +125°C Shunt Capacitance C0 3pF Max. Drive Level DL 1 ~ 50μW (10μW Typ.) Load Capacitance CL 6pF, 7pF, 8pF, 9pF, 10pF 12pF, 16pF, 18pF, 20pF Aging Faging ±3 ppm Max. Storage Temperature Range TSTR -55°C ~ +125°C Conditions at 25°C -20°C ~ +70°C -30°C ~ +85°C -40°C ~ +85°C -40°C ~ +125°C at 25°C ± 3°C,first year Motional Resistance (ESR) Fundamental 9.9 ~ 12 MHz 12 ~ 16 MHz 16 ~ 54 MHz Rev. 1.04 150Ω Max. 100Ω Max. 60Ω Max. Page 1 www.qstproducts.com QT325G MHz Crystal Fuel The Digital World Dimensions Ordering Information QT325G - 27.000M A H E Frequency in Hz - T Packaging Method T Please contact us for available frequencies Tape & Reel Load Capacitance Frequency Tolerance (at 25°C) A D E ± 30 ppm ± 20 ppm ± 10 ppm Frequency Stability (over Temp.) A D E T G H I K Rev. 1.04 ± 30 ppm ± 20 ppm ± 10 ppm ± 10 ppm ± 50 ppm ± 30 ppm ± 20 ppm ± 60 ppm B Y V C Q E I J 6 pF 7 pF 8 pF 9 pF 10 pF 12 pF 16 pF 18 pF ( -20°C ~ +70°C ) ( -20°C ~ +70°C ) ( -20°C ~ +70°C ) ( -30°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +125°C ) Page 2 www.qstproducts.com QT325G MHz Crystal Fuel The Digital World Packing (Unit: mm) (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 5°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.04 60 sec Page 3 Time (sec) www.qstproducts.com
QT325G-19.200MAGJ-T
物料型号:QST QT325G MHz Crystal
器件简介:QST的QT325G MHz Crystal是一款用于数字世界的晶体振荡器,具有RoHS合规性、玻璃密封的陶瓷SMD封装。
引脚分配:文档中未明确提供引脚分配信息,但提供了建议的连接和布局图。
参数特性: - 频率范围:9.9MHz至54MHz - 频率容差:±30ppm, ±20ppm, ±10ppm(在25°C时) - 频率稳定性:在不同温度范围内变化,如-20°C至+70°C时为±30ppm,-40°C至+85°C时为±30ppm等 - 工作温度范围:-20°C至+70°C,-30°C至+85°C,-40°C至+85°C,-40°C至+125°C - 并联电容:最大3pF - 驱动电平:1至50mW(典型值10mW) - 负载电容:6pF至20pF,有多个选项 - 老化:第一年内最大±3ppm - 存储温度范围:-55°C至+125°C
功能详解:文档中未提供详细的功能解释,但根据参数特性可以推断其为高精度和高稳定性的晶体振荡器。
应用信息:适用于家庭电子产品、消费产品、笔记本电脑、硬盘、计算机外设、个人电脑、电视、游戏机、相机等。
封装信息:晶体的外部尺寸为长3.2mm、宽2.5mm、高0.8mm,采用玻璃密封的陶瓷SMD封装。
QT325G-19.200MAGJ-T 价格&库存
很抱歉,暂时无法提供与“QT325G-19.200MAGJ-T”相匹配的价格&库存,您可以联系我们找货
