QT532G-27.000MAAV-T
QT532G-27.000MAAV-T
    QST(矽睿)
    SMD-2
    无源晶振 50Ω 27MHz 8pF ±30ppm -20℃~+70℃ SMD-2
QT532G-27.000MAAV-T 数据手册
QT532G MHz Crystal Fuel The Digital World Features ● ● ● ● Applications Frequency range : 8MHz to 54MHz Glass sealing, ceramic SMD package External dimensions (mm) L : 5.0 x W : 3.2 x H : 1.2 RoHS compliant Contains Pb, exempted by RoHS directive ● ● ● ● ● PC, TV, Game, Camera Notebook, Hard disk Computer peripherals Home electronics Consumer products Electrical Characteristics Item QT532G Frequency Range F0 8MHz ~ 54MHz Frequency Tolerance Ftol ±30ppm, ±20ppm Frequency Stability over Operating Temperature Range (refer to 25°C) Fstab Operating Temperature Range TOTR ±30 ppm ±20 ppm ±30 ppm -20°C ~ +70°C -40°C ~ +85°C Shunt Capacitance C0 5pF Max. Drive Level DL 1 ~ 200μW (100μW Typ.) Load Capacitance CL 12pF, 18pF, 20pF Aging Faging ±3 ppm Max. Storage Temperature Range TSTR -55°C ~ +125°C Conditions at 25°C -20°C ~ +70°C -40°C ~ +85°C at 25°C ± 3°C,first year Motional Resistance (ESR) Fundamental 8 ~ 12 MHz 12 ~ 54 MHz Rev. 1.03 80Ω Max. 50Ω Max. Page 1 www.qstproducts.com QT532G MHz Crystal Fuel The Digital World Dimensions Ordering Information QT532G - 8.000M - A A J - T Frequency in Hz Packaging Method Please contact us for available frequencies T Tape & Reel Load Capacitance Frequency Tolerance (at 25°C) A D ± 30 ppm ± 20 ppm E J K 12 pF 18 pF 20 pF Frequency Stability (over Temp.) A D H Rev. 1.03 ± 30 ppm ( -20°C ~ +70°C ) ± 20 ppm ( -20°C ~ +70°C ) ± 30 ppm ( -40°C ~ +85°C ) Page 2 www.qstproducts.com QT532G MHz Crystal Fuel The Digital World Packing (Unit: mm) (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 5°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.03 60 sec Page 3 Time (sec) www.qstproducts.com
QT532G-27.000MAAV-T
物料型号:QT532G MHz Crystal
器件简介:该晶体振荡器适用于笔记本、硬盘计算机外围设备、PC、电视、游戏机、相机等消费电子产品。
引脚分配:文档中提供了晶体振荡器的顶视图、侧视图和底视图,但未明确列出引脚分配
参数特性: - 频率范围:8MHz至54MHz - 频率容差:±30ppm或±20ppm(25°C时) - 频率稳定性:在不同温度范围内变化 - 工作温度范围:-20°C至+70°C或-40°C至+85°C - 并联电容:最大5pF - 驱动电平:1至200mW(典型值100mW) - 负载电容:12pF、18pF、20pF - 老化:第一年最大+3ppm - 存储温度范围:-55°C至+125°C
功能详解:文档中未提供详细的功能解释,但晶体振荡器通常用于为电子设备提供稳定的时钟信号。
应用信息:适用于数字世界的各种应用,如消费电子产品。
封装信息:提供了晶体振荡器的尺寸和建议的布局,以及订购信息,包括频率、包装方法和负载电容等选项。
QT532G-27.000MAAV-T 价格&库存
很抱歉,暂时无法提供与“QT532G-27.000MAAV-T”相匹配的价格&库存,您可以联系我们找货
