XK12M00000S700
XK12M00000S700
    NEXTGEN
    HC49S
    无源晶振 12MHz 20pF 25Ω ±10ppm HC49S -40℃~+85℃
XK12M00000S700 数据手册
PART CODE: XK12M00000S700 SPECIFICATION SHEET SPECIFICATION SHEET NO. N0207-XK1200000S700 DATE Feb. 12, 2021 REVISION A0 DESCRIPITION SMD Crystal, 49SSMD Type, L11.4*W4.7*H3.0mm, 2 pads, 12.00MHz, +/-10ppm, CL 20pF, Stability +/-50ppm @Operating Temp. Range -20°C ~+70°C, ESR 25 ohm Max, Tape/Reel, Reflow Profile Condition 260 °C Max. RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER TGS CSSM2 12M0A10-20-50-20-25 TLF PART CODE XK12M00000S700 VENDOR APPROVE Issued/Checked/Approved DATE: Feb. 12, 2021 CUSTOMER APPROVE DATE: NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: XK12M00000S700 SMD CRYSTAL 49SSMD TYPE 2 PADS MAIN FEATURE • SMD Crystal, 49SSMD Type, L11.4*W4.7*H3.0mm, 2 pads • Low cost, High precision, High frequency stability • Reflow Profile Condition 260 °C Max. • Wide Frequency Range • Cross more competitors part • RoHS/RoHS III compliant APPLICATION • Bluetooth, wireless communication set • Communication Electronics RFQ PART CODE GUIDE Request For Quotation XK 12M00000 S 700 1 2 3 4 1) XK: Part family Code for SMD Crystal, 49SSMD Type, L11.4*W4.7*H3.0mm, 2 pads (CSSM2) 2) 12M00000: Frequency range code for 12.00000MHz 3) S: SMD type, Package Tape/Reel, 1000pcs/Reel 4) 700: Specification code for original part No.: TGS CSSM2 12M0A10-20-50-20-25 TLF MORE FREQUENCY RANGE AVAILABLE (MHz) 3.579545 3.6864 4.0000 4.09600 4.194304 6.0000 7.3728 8.00000 9.8304 10.000 11.0592 12.000 12.288 14.31818 13.5600 `16.0000 18.432 19.200 20.000 22.1184 24.000 25.0000 26.000 27.0000 32.0000 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: XK12M00000S700 SMD CRYSTAL 49SSMD TYPE 2 PADS DIMENSION (Unit: mm, Tol. +/-0.15mm) Image for reference Marking 1 Line 1: Company Code + CL value Line 2: Freq. Range+ QC Code (A~Z) CSSM2 Marking 2 (Option) Line 1: Frequency Range H: 3.0 +/-0.2 Recommend Pad Layout NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: XK12M00000S700 SMD CRYSTAL 49SSMD TYPE 2 PADS ELECTRICAL PARAMETERS Parameter Part No. Symbol Units Value Min. Original Manufacturer Typical Condition Max. TGS TGS Crystals Holder Type CSSM2 SMD Crystal, 49SSMD Type, L11.4*W4.7*H3.0mm, 2 pads Frequency Range 12M0 MHz 12.000 Mode of Oscillation A Frequency Tolerance 10 ppm Load Capacitance -20 pF Stability over Operation Temperance -50 ppm -50 +50 Operation Temperance -20 °C -20 +70 °C -40 +85 Storage Temperance Equivalent Series Resistance (ESR) -25 AT Fundamental -10 +10 20 Ω 25 Drive Level μW 100 Shunt Capacitance (C0) pF Motional Capacitance (C1) fF N/A DLD2 Ω N/A FLD2 ppm N/A RDL2 Ω N/A SPDB dB N/A Aging ppm/year Insulation Resistance Others MΩ @25°C 0 7.0 ±3 500 @1st year @100VDC ± 15VDC Package T Tape/Reel RoHS Status LF RoHS III compliant Add Value N/A Internal Control Code * N/A Note: 1) Original Part Number: TGS CSSM2 12M0A10-20-50-20-25 TLF 2) * Internal Control Code- 2 letter or digits; Blank: N/A NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: XK12M00000S700 SMD CRYSTAL 49SSMD TYPE 2 PADS RELIABILITY Test Items Test Method And Conditions Reference Documents High Temperature High Humidity Storage Temperature: 85℃±3℃ Relative Humidity:85%RH Time: 96 Hours JIS C5023 High Temperature Storage Temperature: 125℃±3℃ Time: 96 Hours. MIL-STD-883E Method 1005.8 Low Temperature Storage Temperature: -40℃±3℃ Time: 96 Hours. MIL-STD-883E Method 1013 Thermal Shock Temperature 1: -55℃±5℃ Temperature 2: 85℃±5 ℃ Temperature change between T1 and T2 5 min 10cycles maintain T1 and T2 for 30 minutes each cycle MIL-STD-202F Method 107 Condition A Resistance to Solder Heat Solder Temperature: 260℃±5℃ Time: 10±1 Seconds MIL-STD-202F Method 210E Solderability The solder pot temperature is 245±5℃ , dwell time 5±0.5sec J-STD-002B Drop Test 3 Times Free Fall from 50cm height table to 3cm thickness hard wood board J-STD-002B Mechanical Shock Half sine wave,1000 G 3 Times for all 3 directions(X,Y Z) MIL STD 202F Method 213B Vibration Frequency Range: 10Hz~55Hz Amplitude: 0.75mm 2 Hours in each direction, total 6 Hours MIL-STD-883E Method 2007.3 Leakage Test Take measurements with a helium Leakage detector Leakage Rate≤1×10ˉ³Pa cm³/s MIL-STD-883E NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: XK12M00000S700 SMD CRYSTAL 49SSMD TYPE 2 PADS SUGGESTED REFLOW PROFILE (For Reference Only) Total time: 200 Sec. Max. Solder melting point: 220℃ Profile Feature Pb-Free Assembly Average Ramp-up Rate (Ts Max to Tp) 3℃/second Max Preheat Temperature Min (Ts Min.) 125℃ Temperature Max (Ts Max.) 200℃ Time (ts Min. to ts Max.) 60~180 seconds Temperature (TL) 217℃ Time (tL) 60~150 seconds Time maintained above Peak/Classification Temperature (Tp) 260 ℃ Time within 5℃ of actual Peak Temperature (tp) 20~40 seconds Ramp-down rate 6 ℃ /Second Max. Time 25 ℃ to Peak Temperature 8 minutes Max. Suggest reflow times 3 Times Max. NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: XK12M00000S700 SMD CRYSTAL 49SSMD TYPE 2 PADS TAPE/REEL (Unit: mm) All Devices are packed in accordance with EIA standard RS-481-2 and specifications., 1000pcs/Reel Symbol Dimension A 5.0±0.1 B 15.0±0.2 C 24.0±0.3 D 11.05±0.1 E 1.75±0.1 F 8.0±0.1/12.0±0.1 G 5.0±0.1 H 0.5±0.1 I 2.4±0.2 J 24.4+2.0/-0.0 K 100.0±1.0 L 330 DISCLAIMER NextGen Components, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com
XK12M00000S700 价格&库存
很抱歉,暂时无法提供与“XK12M00000S700”相匹配的价格&库存,您可以联系我们找货
