QTM325-32.768MCE-T
QTM325-32.768MCE-T
    QST(矽睿)
    SMD3225_4P
    有源晶振 32.768000 MHz 2.5V -40℃~+85℃ CMOS
QTM325-32.768MCE-T 数据手册
QTM325 MHz CMOS Oscillator Fuel The Digital World Features ● ● ● ● ● ● ● Applications Frequency range : 1MHz to 133MHz SMD seam sealing ceramic package Supply voltage : 1.8V ~ 3.3V CMOS output Tri-state function available External dimensions (mm) L : 3.2 x W : 2.5 x H : 1.0 RoHS compliant & Pb free ● ● ● ● ● Networking, Server, Storage Wireless communications Fibre channel, Ethernet, SATA, SAS, PCI-E, USB, WLAN, xDSL, xPON PC mainboard, Notebook, HDD, SSD, Graphics card, Computer peripherals Audio, Video, Gaming, Printer, DSC, IP CAM, Consumer products Electrical Characteristics Item Frequency Range (F0) QTM325 Conditions 1MHz ~ 133MHz ±50 , ±25 ppm -10°C ~ +70°C; Note [1] ±50 , ±25 , ±20 ppm -40°C ~ +85°C; Note [1] Frequency Stability (Fstab) Operating Temperature Range (T OTR) Supply Voltage (VDD) -10°C ~ +70°C -40°C ~ +85°C 1.8V, 2.5V, 3.3V VDD ± 10% 10 mA Max. 1MHz ~ 75MHz 15 mA Max. 75MHz ~ 133MHz Current Consumption (IDD) Output Type CMOS Output Load (CL) 15 pF Output Voltage High (VOH) 90% VDD Min. Output Voltage Low (VOL) 10% VDD Max. Rise & Fall Time (Tr / Tf) 8 ns Max. Duty Cycle Start-up Time Enable Voltage High, Logic "1" Enable Voltage Low, Logic "0" Phase Jitter, RMS Aging (Faging) Storage Temperature Range (TSTR) 45% ~ 55% 5 ms Max. 70% VDD Min. 30% VDD Max. 1 ps Max. ±3 ppm Max. 10% ~ 90% of VDD Input to Pin1 Note [2] Note [3] at 25°C±3°C,first year -55°C ~ +125°C Notes: [1] Inclusive of frequency tolerance at 25°C, 1st year aging at 25°C, and variations over operating temperature, supply voltage, and load. [2] Output will be enabled if Pin1 is Logic "1" or open; Output will be disabled if Pin1 is Logic "0". [3] Freq. 10MHz~40MHz, integrated 12kHz~5MHz; Freq. >40MHz, integrated 12kHz~20MHz. Rev. 1.04 Page 1 www.qstproducts.com QTM325 MHz CMOS Oscillator Fuel The Digital World Dimensions (Unit: mm) Ordering Information QTM325 - 30.000M B E - T Frequency in Hz Packaging Method T Please contact us for available frequencies Frequency Stability Supply Voltage B C D Rev. 1.04 Tape & Reel B A E D I 3.3 V 2.5 V 1.8 V Page 2 ± 50 ppm ± 25 ppm ± 50 ppm ± 25 ppm ± 20 ppm ( -10°C ~ +70°C ) ( -10°C ~ +70°C ) ( -40°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +85°C ) www.qstproducts.com QTM325 MHz CMOS Oscillator Fuel The Digital World Packing (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 10°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.04 60 sec Page 3 Time (sec) www.qstproducts.com
QTM325-32.768MCE-T 价格&库存
很抱歉,暂时无法提供与“QTM325-32.768MCE-T”相匹配的价格&库存,您可以联系我们找货
