VLEUWLJTNF-125.000000 数据手册
High Frequency, Very Low Noise and
Low g-Sensitivity VCXO VLEU-Type series
14 x 9mm SMD package
FEATURE
- VLEU-Type series is a high frequency high performance VCXO offering high
frequency and very low phase noise/Low g-Sensitivity. The part comes in a
small SMD package which makes it suitable for reflow soldering during pick
and place assembly.
- Low Phase Noise
- Low g-Sensitivity
- Small SMD Package
- Low Power Consumption
TYPICAL APPLICATION
- Instrument
- Microwave Communication
- Test & Measurement
- Telecom Systems
- Satellite Communication
DIMENSION (mm)
[ BOTTOM VIEW ]
5.08 ± 0.10
6.00 ± 0.10
9.10 ± 0.15
#2
#2
5.08 ± 0.10
5.08
#1
2.54
1.524
3.60 ± 0.15
[ SIDE VIEW ]
#4
5.5
#3
#3
1.55 ± 0.10
13.90 ± 0.10
#1
RoHS Compliant
SOLDER PAD L AYOUT (mm)
[ TOP VIEW ]
#4
Actual Size
Pin#
1
2
3
4
12.90 ± 0.20
Function
Vcon
1.6
GND
Output
VDD
ELECTRICAL SPECIFICATION OUTPUT (PIN = “R.F. OUTPUT”)
Max.
Unit
Frequency (Fo)
50
125
MHz
Frequency Stability
(Overall)
-25
+25
ppm
Parameter
Min.
Typ.
Operating Temperature
-20oC ~ +70oC
Range
-40oC ~ +85oC
Storage Temperature
Range
-45oC ~ +90oC
Waveform
o
C
o
C
CMOS
Duty Cycle
45
Rise / Fall Time
Level
Test Condition
Standard Frequency:100MHz,
122.88MHz, 125MHz
Frequency stability includes
frequency tolerance@25 oC and
frequency stability vs.
operating temperature range
and voltage variance and 10
years aging.
VOL
VOH
3
nSec
0.5
V
4.5
(20%VDD ~ 80%VDD)
V
Load
15
g-Sensitivity
1.5
Phase Noise
(100MHz)
(Max.)
55
pF
ppb/g
-80
dBc/Hz
@ 10Hz
-115
dBc/Hz
@ 100Hz
-140
dBc/Hz
@ 1KHz
-160
dBc/Hz
@ 10KHz
-168
dBc/Hz
@ 100KHz
-170
dBc/Hz
@ 1MHz
Note: not all combination of options are available. Other specifications may be available upon request.
Specifications subject to change without notice.
www.taitien.com
sales@taitien.com.tw
Rev(6) 04/2021
83
ELECTRICAL FREQUENCY ADJUSTMENT (PIN = “VCO INPUT”)
Parameter
Min.
Pulling Range
Typ.
Max.
±25
Control Voltage
+3.3
Slope
Positive
Center Voltage
+1.65
VC Input Impedance
V
V
-10
Modulation Bandwidth
Test Condition
ppm
Linearity
Unit
+10
1
KHz
100
Mohm
INPUT POWER (PIN = “+VDC”)
Parameter
Voltage
Min.
Typ.
Max.
+3.135
+3.3
+3.465
V
30
mA
Current
Unit
Test Condition
At maximum supply voltage
ENVIRONMENTAL
Parameter
Reference Std.
Vibration Test
DIN EN 60068-2-6
Thermal Shock
DIN EN 60068-2-14
Mechanical Shock
DIN EN 60068-2-27
Test Condition
10~55Hz, 0.75mm Peak; 55~2000Hz, 10g Peak.
10 Cycles; 3 axis; 1Oct./min.
30 min. @each temperature 10 cycles,
Transfer
VLEUWLJTNF-125.000000 价格&库存
很抱歉,暂时无法提供与“VLEUWLJTNF-125.000000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+491.721491+63.65760
- 10+476.0919510+61.63422
- 国内价格 香港价格
- 100+388.96692100+50.35513
