QTV532P-122.880MBB-T 数据手册
QTV532P
Voltage Controlled Crystal Oscillator
Fuel The Digital World
Features
Applications
Frequency range : 30MHz to 250MHz
SMD seam sealing ceramic package
Supply voltage : 3.3V
LVPECL output
Fundamental solution
Low phase noise and phase jitter
Tri-state function available
External dimensions (mm)
L : 5.0 x W : 3.2 x H : 1.2
RoHS compliant & Pb free
Wireless communications,
Smallcell, Base station
Fibre channel, SONET, SDH,
Ethernet
Set-top box (STB)
xDSL, VoIP, Cable modem
Digital TV, Digital audio
Phase-locked loop (PLL) circuits
Electrical Characteristics
Item
Frequency Range (F0)
Operating Temperature Range (T OTR)
QTV532P
30MHz ~ 250MHz
-40°C ~ +85°C
-40°C ~ +105°C
Supply Voltage (VDD)
Current Consumption (IDD)
3.3 V
80 mA Max.
Output Type
LVPECL
Output Load
50Ω (VDD - 2.0V)
Output Voltage High (VOH)
VDD - 1.025V Min.
Output Voltage Low (VOL)
VDD - 1.62V Max.
Rise & Fall Time (Tr / Tf)
0.5 ns Max.
Duty Cycle
45% ~ 55%
Start-up Time
10 ms Max.
Enable Voltage High, Logic "1"
70% VDD Min.
Enable Voltage Low, Logic "0"
30% VDD Max.
Absolute Pulling Range (APR)
±50 ppm Min.
Control Voltage Range
0V ~ 3.3V
Linearity
10% Max.
Phase Noise (F0 = 122.88MHz)
-128 dBc/Hz Typ.
Phase Jitter (F0 = 122.88MHz)
0.11 ps Typ.
Storage Temperature Range (TSTR)
Rev. 1.01
Conditions
VDD ± 10%
RL = 50Ω to VDD - 2.0V
20% ~ 80% of output swing
Input to Pin2
Note [1]
Note [2]
Nominal 1.65V
at 1kHz offset
12kHz ~ 20MHz, RMS
-55°C ~ +125°C
Page 1
www.qstproducts.com
QTV532P
Notes:
[1] Output will be enabled if Pin2 is Logic "1" or open; Output will be disabled if Pin2 is Logic "0".
[2] Absolute Pulling Range (APR) = Pulling Range - (Frequency tolerance at 25°C, variations over
temerature, supply voltage, and aging).
Dimensions
Pin function
Pin 1
VC
Pin 2
OE
Pin 3
GND
Pin 4
OUT
Pin 5
OUT
VDD
Pin 6
Recommended pad layout
(Unit: mm)
* Pad dimension tolerance is ±0.2mm
* Power supply decoupling capacitor is required.
Ordering Information
QTV532P
122.88M B B
Frequency in Hz
T
Packaging Method
T
Please contact us for
available frequencies
Tape & Reel
Supply Voltage
B
Rev. 1.01
B
G
3.3 V
Page 2
-40°C ~ +85°C (APR ± 50 ppm)
-40°C ~ +105°C (APR ± 50 ppm)
www.qstproducts.com
QTV532P
Packing
(Unit: mm)
Reflow Profile
Solder melting point : 220°C ± 10°C, 60 sec. Min., 200 sec. Max.
Peak temperature : 260°C ± 10°C, 10 sec. Min., 30 sec. Max.
(°C)
10 sec
260
220
180
150
120 sec
Rev. 1.01
60 sec
Page 3
Time (sec)
www.qstproducts.com
QTV532P-122.880MBB-T 价格&库存
很抱歉,暂时无法提供与“QTV532P-122.880MBB-T”相匹配的价格&库存,您可以联系我们找货
