S733025T-14.31818-15-R
    AKER(安碁科技)
    SMD7050_4P
    有源晶振 14.318180MHz 3.3V -20℃~+70℃ HCMOS
S733025T-14.31818-15-R 数据手册
Revisions Ltr Date Appr RoHS Compliant Pb - Lead Free Electrical Specifications: Frequency Range 0.500~156.250 0.500~156.250 0.500~156.250 0.500~40.000 0.500~100.000 MHz Frequency Stability ±20 ~ ±100 ppm ±3 ppm Max. Aging per Year Operating Temperature Range Standard -10 ~ +70 Extended -40 ~ +85 -55 ~ +125 Storage Temperature Range 1.8 ± 5% Supply Voltage Input Current Output Voltage °C 2.5 ± 5% 3.3 ± 10% 1.62 ~ 3.63 5.0 ± 10% 0.500 to 9.999MHz 5 6 7 7 10 10.000 to 19.999MHz 6 7 7 7 15 20.000 to 31.999MHz 6 8 12 12 25 32.000 to 49.999MHz 15 20 20 20 35 50.000 to 79.999MHz 15 20 25 50 80.000 to 99.999MHz 20 25 30 60 100.000 to 156.250MHz 25 30 40 80 VDD mA Max. Logic High (Voh) 90% VDD Min. Logic Low (Vol) 10% VDD Max. Output Symmetry (Duty Cycle) Standard 40 ~ 60 ( at 50% VDD) Tight 45 ~ 55 ( at 50% VDD) % 15 Output Load pF Max. 30 Rise and Fall Time 0.500 to 31.999MHz 5 5 10 10 10 32.000 to 49.999MHz 5 5 10 10 6 50.000 to 79.999MHz 4 4 8 5 80.000 to 99.999MHz 3 3 5 5 100.000 to 156.250MHz 3 3 4 4 1 Phase Jitter (12 KHz to 20 MHz) ps Max. RMS Tri-State Enable-Disable Function 10 Start Up Time ms Max. Temperature stability is Inclusive of all conditions: Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage change, output load change, shock, vilbration, and 1st year aging at +25°C. Specification Title: No.11-3 Jianguo Rd., T.E.P.Z. 42760 Taiwan All dimensions are millimeters. CAD: TCR Review: EG Appr: JL Page: 1/4 Date: July 1,2020 ns Max. HCMOS Output Clock Oscillator Low Profile 5.0 x 7.0 millimeter Surface Mount General Product Specification Part Number: www.aker-usa.com S7 Series Mechanical Outline and Solder Pad Layout: 7.0 ± 0.15 5.0 ± 0.15 #4 Ceramic Base Metal Lid #3 AKER #1 #2 1.4 Max. 5.08 5.08 #4 #3 2.0 1.1 4.20 #2 2.60 #1 1.4 1.8 Pin Connection PIN No. #1 Enable/Disable Function PIN #1 Connection Enable/Disable #2 GND #3 Output #4 VDD PIN #3 HIGH or OPEN Operating LOW High Impedance Package is Seam Sealed Ceramic-Metal. Terminator Pads are Ni/Au. Dimensions are millimeters. Page: 2/4 Date : July 1,2020 www.aker-usa.com P/N: S7 Series +0.1 1.5 -0.0 2.0 ± 0.1 1.75 ± 0.1 Carrier Tape Dimensions: 4.0 ± 0.1 0.3 ± 0.05 5° (max) A B 8.0 ± 0.1 Ko:2.0 Ao:5.4 5° (max) A-A SECTION Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 B-B SECTION AKER +0.1 1.7 -0.0 AKER AKER AKER A Bo:7.9 Pin #1 16.0 ± 0.3 7.5 ± 0.1 B Date : July 1,2020 www.aker-usa.com P/N: S7 Series How to build a Part Number: Series Package S 7 Parameter 5.0 x 7.0 mm Supply Voltage 50 33 25 18 M +5.0 VDD ± 10% +3.3 VDD ± 10% +2.5 VDD ± 5% +1.8 VDD ± 5% +1.62 ~ +3.63 VDD Temperature Stability 10 05 025 020 ±100 ppm ±50 ppm ±25 ppm ±20 ppm See Notes T 40%~60% 45%~55% Duty Cycle Frequency 0.500~156.250 MHz - Temperature Range See Notes X -10 ~ +70 °C -40 ~ +85 °C - Output Load 15 30 pF Max - Packaging M R 250pcs Reel 1000pcs Reel Part Number Example: S73305T-50.000-X-15-R S7: 5.0 x 7.0 mm SMD Package 33: +3.3±10% VDD Supply Voltage 05: ±50 ppm Temperature Stability T: 45%~55% Tight Symmetry 50.000 MHz Nominal Frequency X: -40 ~ + 85°C Extended Temperature Range 15: 15 pF Max Output Load R: Tape and Reel Packaging - 1000pcs Reel Notes: 1- Standard Duty Cycle and Temperature Range do not need to be included in Part Number description. 2- Product is shipped in Tape and Reel configuration. 3- Quantities less than 250pcs are shipped in tape only. 4- Specification subject to change without notice. Page: 4/4 Date : July 1,2020 www.aker-usa.com P/N: S7 Series
物料型号:S7系列 器件简介:HCMOS输出时钟振荡器,低轮廓5.0 x 7.0毫米表面贴装 引脚分配: - #1:使能/禁用 - #2:地(GND) - #3:输出 - #4:电源(VDD)
参数特性: - 频率范围:0.500至156.250MHz - 频率稳定性:+20至±100ppm - 老化率:每年±3ppm - 工作温度范围:标准型-10至+70℃,扩展型-40至+85℃ - 存储温度范围:-55至+125℃ - 供电电压:1.8+5%至5.0±10% - 输入电流:根据频率不同,最大值从5mA至25mA不等 - 输出电压:高电平(Voh)至少90% VDD,低电平(Vol)最大10% VDD - 输出对称性(占空比):标准型40%至60%,紧密型45%至55% - 输出负载:最大15至30pF - 上升和下降时间:根据频率不同,最大值从3ns至10ns不等 - 相位抖动:12kHz至20MHz,最大1ps RMS - 使能/禁用功能:三态
功能详解: - 使能/禁用功能允许振荡器在高电平或开路时工作,在低电平时进入高阻抗状态。
应用信息:文档未提供具体应用信息,但时钟振荡器通常用于为电子设备提供时钟信号。
封装信息: - 封装类型:密封陶瓷金属 - 尺寸:5.0 ± 0.15 x 7.0 ± 0.15毫米 - 焊盘布局:建议布局图提供详细信息
S733025T-14.31818-15-R 价格&库存
很抱歉,暂时无法提供与“S733025T-14.31818-15-R”相匹配的价格&库存,您可以联系我们找货
